Whats the scariest thing youve seen on a rod?
Discussion in 'The Hokey Ass Message Board' started by Lobucrod, Feb 7, 2007.
  1. wildearp
    wildearp
    from tucson, az
    We have a local guy in Tucson that has his frame rail practically sitting on his tie rod. YOu can see the rub marks. When he hits a bump, no steering.........
    I see lots of guys with too severe of an angle on their steering u-joints and even top builders that have the steering shaft rubbing on the headers.
    In todays 4 disc brake light weight ricer world, not running front brakes on a hot rod is a good plan for a rear ender and a law suit.
  2. that is totally old school!
  3. What? No Dennis RODman in a wedding dress pics????
  4. rottenpop
    rottenpop
    In 50 x 50 box, we trust.
    Just in case that fails, we have a br*** skid plate. Or radiator.
    Friction brakes?
  5. plym49
    plym49
    from Earth
    And, to top it off, the generator is mounted on the frame and the adjuster is on the motor. Guess the fan belts doubles as a motor mount shock absorber. LOL.
  6. Model A Mark
    Model A Mark
    from dallas
    hah omg, funniest post i seen in a long time..
    idiots a****st us all ...... and we let em breed
  7. onlychevrolets
    onlychevrolets
    I found this "car" at the Red Neck Rumble.....now this **** just aint cool and it dam-sho aint safe![​IMG]
  8. moter
    moter
    wow!!! I loose count of how many thing are not right on this...
  9. onlychevrolets
    onlychevrolets
    This **** looks like something off " JUNK YARD WARS"
  10. onlychevrolets
    onlychevrolets
    but it does have a cotter pin the the tie rod, that makes up for the dry rotted tire , the empty brake drum, but NOT for the ugly *** home made steering arm! Who gets off building this dangerous ****?
  11. Royalshifter
    Royalshifter
    Moderator
    This kind of garbage is going to ruin the coolest hobby on the planet someday.:mad:
  12. onlychevrolets
    onlychevrolets
    High dollar exhaust...NO, it's not one of mine![​IMG]
  13. Little Wing
    Little Wing
    from Northeast
    and "Oprah" bumper sticker
  14. That coloradoan will be chiming in to defend this **** soon.
    Building & driving **** that is cobbled together like this is .....
    well the proper words escape me
  15. onlychevrolets
    onlychevrolets
    are the words " ****ING DUMB" ?
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    OH The Humanity
    someone please make it stop!
  17. Mazooma1
    Mazooma1
    I don't think this has been posted yet...sorry if it has
  18. leon renaud
    leon renaud
    from N.E. Ct.
    OK I have seen a lot of this on late 50s stock cars usually with a stove pipe for a collector!
  19. DirtyThirty
    DirtyThirty
    from nowhere...
    "lookee, hunny...iz 'jus like a Dooosenburg, nay-ow"!:D
    Also featuring the standard-issue throttle chain...from a toilet.
    I am not sure how the piano-wire looking thing running back from the linkage over the side of the cowl fits into this thing...
    Is that the 'ol electrical-tape shock boot I see, too?
    Looks like it has brake lights, at least...
  20. hugh m
    hugh m
    from ct.
    Was thinking of posting a couple of stupid things I found on cars I've bought over the years, but couldn't even come close to this stuff...
  21. swade41
    swade41
    from Buffalo,NY
    Now don't go coppying the idea of a wood screw down the middle of the spring pack now.
  22. swade41
    swade41
    from Buffalo,NY
    Did you wonder how he even bled the rear brakes with the spring shackel welded over the back of the wheel cylinder ? Those rear rods after being wrapped all the way around the rear end housing were welded to some all thread. The altenator on this was mounted on the frame rail too, by the way it did have a Hurst mount on the front of the engine.
  23. DirtyThirty
    DirtyThirty
    from nowhere...
    I need more info on this...I'm lost as to how this is supposed to function, and, honestly, its not even THAT crude looking, as far as how it was done, but I don't understand how this is supposed to function...I see lever-shocks, o.k., fine...But maybe its the angle of the pic, or whatever, but what is coming from under the bone/bottom heim joint, and is that attached to the frame???! How is the suspension supposed to move independently of the frame??? What is the spring mounted to??? Is THAT the tie rod right up against the spring???
    I'm lost...Any more shots of this?
  24. DirtyThirty
    DirtyThirty
    from nowhere...
    This thing is AMAZING.
    Hands down...no contest...
    A highwater mark in horrible.
    Just wow.
    Still reeling.
  25. When I was about 14 years old (about 1975) my grandfather p***ed away and my Dad got to keep his 64 Chevy Nova 4 door. Apparently the fuel pickup inside the tank clogged at some point, so Grandpa rigged a jerry can on the back p***enger's side floor pan and drilled a hole in the floor for the fuel line!!! The first couple of times that my Dad stopped for gas we got strange looks from everyone else in the gas station. Fortunately my Dad took it apart as soon as the weather got nice, spent a whole ten minutes cleaning the pickup, and got it working PROPERLY again. (OK, it wasn't a "rod" but it was still darn scary!)
  26. Apparently that bar under the heim joint runs under the frame and keeps the bars parallel. The shock absorber mounting is actually similar to the Plymouth Prowler. They have a funky "rocker arm" system to actuate their shock absorbers mounted near the center of the car too. I'll dig around for a photo.
  27. RichG
    RichG
    That shock absorber rocker looks similar in concept to the formula race cars, or do my eyes deceive me?
  28. old1946truck
    old1946truck
  29. DirtyThirty
    DirtyThirty
    from nowhere...
    O.K., that was my other presumption on that bar...I've seen shock systems like this too, on Sprint cars??? I think...dirt cars, anyway...but my thinking is that bar going under the frame looks awfully close ALREADY to the frame rails....what happens during suspension travel/spring compression??
