thanks. ordered a catalog. so - other than buying a custom spring - how would I go about mounting my 1940 front axle using a transverse leaf setup and the stock Model A spring mount? dan
Simple...change your perches to the earlier style. It may benefit you to buy the "longer" perches like Speedway sells, since the axle/wishbone ***embly is thicker than say, a stock Model A's. Then cut off the forward spring mounting portion of your wishbones, and carefully round the part around the perch with a die grinder (or file) to match the bottom.
