1952-59 Ford Whats this all about?
Discussion in 'Off Topic Hot Rods & Customs' started by Ferrell592, Apr 18, 2012.
  1. Ferrell592
    Ferrell592
    Ok guys, any idea what this is all about? I took these off the front of my 54 customline and noticed the same cuts in the drum on both sides. This isn't something done at the factory, so what the heck?[​IMG]
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    It's not uncommon to see those,Ford did that for two reasons as a vent and a way to blow out dust ac***ulation.My '54 has them too. Doing a brake job?
  3. Ole don
    Ole don
    On my 54, there were adjustments for the shoe anchors. I thought that the slots were for a feeler gauge for adjusting those anchors. I just threw new shoes in an ran it. I used only the screw adjustment on the bottom.
  4. Retro Jim
    Retro Jim
    I have them on my 50 and 55 so nothing to be concerned about !
    Jim
  5. Ferrell592
    Ferrell592
    Interesting, ok. I didn't think it was factory. Since it was not a clean cut. I'm rebuilding the whole frontend. Was going to go to feont disc conversion but decided to leave it drum because of cost.
  6. 54HotRod
    54HotRod
    I would imagine its was also used as a cooling aid so that the heat could escape faster through the vent.
  7. riskybiz
    riskybiz
    Before I did the drop spindles/disk brake conversion on my two 54's and 55. The original drums had the same cuts in them. I remember when I rebuilt the brakes on my father-in-laws 56 CrownVictoria and the 56 I had, they had the same cuts too.
  8. Ferrell592
    Ferrell592
    Ultimately, I'd like to change over to disc and p/s. But for now, I just want to get it back on the road. I can always do the change overs later
  9. lincolnhead
    lincolnhead
    from Marysville
    the front conversion isn't that bad on the wallet. you can piece your together. using firebird/camaro calipers and depending on your bolt pattern you want you can use aerostar front disc rotors. just Google for front disc conversions..
    i picked my front disc conversion up for 430.00.
