Technical What's this called?
Discussion in 'The Hokey Ass Message Board' started by '34 Ratrod, Nov 28, 2022.
  1. As the ***le says, what's it called? I have a wide-five axle but this "shaft" has been cut short beyond use and I want to replace it.
    I pillaged the picture off of The HAMB..
    Thanks for your patience with my ignorance!
    Larry
  2. clem
    clem
  3. jimvette59
    jimvette59
    It doesn't look like it was cut it looks like that's a coupler. Probably a six spline drive shaft. See the holes for the pins.
  4. Kerrynzl
    Kerrynzl
    "Splined Coupling Sleeve" [sometimes called "Splined Sleeve"]
    chryslerfan55 and anthony myrick like this.
  5. Squablow
    Squablow
    I would call that the pinion shaft, but I think the '39 one is very short, different than some of the other years of torque tube. Are you sure it's cut down?
  6. Squablow
    Squablow
    Is it the coupler that is cut, or the splined shaft itself?
  7. Knock out the pin.
    They can be fun to remove
  8. Stan Back
    Stan Back
    Looks like the coupler that was inside the torque tube when we ditched the "39" trans and went to the Hydro, which was longer. The guys at Scotty's just figured the driveshaft length with 1/2 or so of it belonging in the coupler, cut the shaft down to that length and ground it down to fit inside the coupler an arc-welded them together.
    That's one of the only things I never broke with the Cyclone.
  9. X38
    X38
    Those are pinned.;)
    Fortunateson, clem and chryslerfan55 like this.
  10. It's the splined shaft that is cut. Thank you. Is it possible to remove and replace it?
  11. ronzmtrwrx
    ronzmtrwrx
    If you’re talking about the splined shaft that comes out of the rear end, then you’re talking about the pinion. So, yes it can be replaced by tearing the rear end down.
  12. Squablow
    Squablow
    OK then that's the pinion shaft, and they're available new and replaceable, so even if yours is cut, it's still a very fixable rearend.
  13. Awesome! Thanks to all for your responses.
    Larry
