whats this motor mount for ?
Discussion in 'The Hokey Ass Message Board' started by lone wolf, Feb 12, 2009.
  1. lone wolf
    lone wolf
    it,s to wide for 41-48 ford.
  2. Little Wing
    Little Wing
    from Northeast
    looks like a chevy
  3. lone wolf
    lone wolf
    i though it was chevy ,but what frame does it go on? it,s too wide to fit the old flathead mounts
  4. ZomBrian
    ZomBrian
    from in IN
  5. Little Wing
    Little Wing
    from Northeast
    it most likely had some kind of frame mounts and that saddle attached to them .. like the Hurst set up
    how long/wide is it ?
  6. Weedburner 40
    Weedburner 40
    Mount is for 55-62 Corvette. The later ones have a crescent notch in the top to clear a byp*** fitting on the top of the waterpump.
  7. propwash
    propwash
    from Las Vegas
    obviously Corvette. You'll note that the way the mount is fabricated, the engine is designed to sit DOWN in the ch***is, much lower than any p***enger car mount. Most Hurst mounts (and others) went under the crank snout/timing cover - this one goes over - look under the hood of any early straight axle Vette - this is what you'll see.
    dj
  8. lone wolf
    lone wolf
    it,s 2ft long, and after looking this over better, it looks like it should mount under the crank pully. also it is pretty heavy.
  9. propwash
    propwash
    from Las Vegas
    Just went out and checked the 57 - looks just a bit different, but just can't be anything else.
    dj
  10. r759ca
    r759ca
    from nor cal
    for sure chevy but not corvette they mount between the waterpump and block dont think i have ever seen a stock mount like that probably aftermarket
  11. 1951bomber
    1951bomber
    from atwater Ca
    may be chevy inline six
