Whats this rack from?
Discussion in 'The Hokey Ass Message Board' started by Chris Melzo, Sep 18, 2009.
  1. Chris Melzo
    Chris Melzo
    from Reno, NV
    I just picked up a 51 business coupe and want to replace the steering rack. Ive looked at mus 2 and pinto racks, but they dont seem to look the same. Its that big bracket to the inside of the steering box thats throwing me off. Any help?
  2. thewishartkid
    thewishartkid
    I was hoping for some breasts!!!!!!!!!!!!!!!
  3. fordcragar
    fordcragar
    from Yakima WA.
    My guess would be 73 and earlier Pinto.
  4. Early Pinto rack for sure. Rob
  5. ranfor
    ranfor
    looks like a nissan 240 about 1973 or a ford caprie rack 1973
  6. fordcragar
    fordcragar
    from Yakima WA.
    If you were looking at Mustang II racks, they would be the same 74-78 and Pinto 74 and later. The earlier Pinto rack was different.
  7. ELpolacko
    ELpolacko
    That looks like an AMC Pacer front end. If so then that would be a Pacer rack.
    Looks stock to that crossmember to me.
  8. hotflint
    hotflint
    Have you looked any late 80s thunderbirds?
  9. 49ratfink
    49ratfink
    what suspension is in it? why do you need to replace it?
  10. pasadenahotrod
    pasadenahotrod
    from Texas
    The early Pinto, 71-73, used a rack very similar to that one. I'd find something a little more heavy duty, like 74-80 Pinto/Mustang II.
  11. Chris Melzo
    Chris Melzo
    from Reno, NV
    Im replacing everything from the steering wheel to the rack. It all looks really old and worn out. the steering binds pretty bad.
  12. frankenstein1948
    frankenstein1948
    Agreed.Looks like early pinto.
  13. Hackerbilt
    Hackerbilt
    Go pull a wheel off and take a picture of the actual suspension so we have HALF a chance of figuring out what the IFS is from!
  14. whid
    whid
    I dont think thats a pacer.......................dave
  15. 55 dude
    55 dude
    jack it up and pull a wheel. that rack has numbers to id it need more pic's
  16. If it binds it might not be the right rack for the front end anyways, as someone else asked what is the rest of the suspension?
  17. ELpolacko
    ELpolacko
    Maybe not, but it sure looks like one from here. The only thing that may indicate you are correct is the bolt for the lower control arm. It doesn't appear to have the eccentric adjuster.
    It's the rubber mount collar on the left side that is making e think this. The early Pinto racks had a cast flange that bolted directly to the crossmember sans the rubber collar.
    Maybe it's real early Pinto and I'm just unfamiliar with it.
  18. Chris Melzo
    Chris Melzo
    from Reno, NV
    Thank you, its a 73 pinto, one year only rack and pinion.
