What's this rear end worth?
Discussion in 'The Hokey Ass Message Board' started by carpok, Feb 20, 2013.
  1. carpok
    carpok
    from Indy
    What's this worth. Thanks. [​IMG]. [​IMG]
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    What would you take for it? Value is really based on internal condition and parts.
    12 spline steel spools are worth s**** weight, just too many of them around. If the pinion nose bearing support is broken or has been repaired it brings the value down.
    Are the axles in it? How wide? 11 or 12 bolt side bell adaptors? Where was the center section and rear cover made? Is it all magnesium? Any history?
    You could increase the value by cleaning it up and being able to answer the above questions. I would probably offer you a couple hundred for it, as is. Shipping is going to be killer unless you can break it down and make smaller boxes.
