What's this shift pattern?
Discussion in 'The Hokey Ass Message Board' started by 5window, Oct 13, 2008.
  1. 5window
    5window
    Most of the automatic shift indicators I've seen read "PNRDL". At Hershey, I bought a piece of chrome that I thought I could cut down and use in my A. But the shift pattern on it is PNDLR". Have I just not paid attention? Can anyone tell me what manufacturer used this pattern? Thanks.
  2. Slag Kustom
    Slag Kustom
    i think my 60 caddy had that pattern
  3. Wesley
    Wesley
    if memory serves me correctly the early powerglides had that pattern.
  4. pan-dragger
    pan-dragger
    i'm thinkin powerglide
  5. dadsmad
    dadsmad
    cast iron powerglide in the 50's
  6. stuart in mn
    stuart in mn
    Could be a 1964 or earlier GM Hydramatic or slim jim transmission, they were PNDLR.
  7. H3O
    H3O
    my friend has that in his 54 chevy.
  8. 55 dude
    55 dude
    old gm turbo-glide, the "R" was for "grade-retard" to slow you down on long hills when towing. they came behind 348's usually with a posi in a tow package. my 60' impala had this combo. people used to burn them up hitting the gas and dropping them in "R"!
  9. Baumi
    Baumi
    I think 60 Pontiac´s also have this shift pattern, if I recall correctly...
  10. Squablow
    Squablow
    What the hell ****** has that? I've NEVER seen that one before.
  11. tjm73
    tjm73
    My Father's '56 Bel-Air convertable has that exact pattern. It's a powerglide.
  12. tjm73
    tjm73
    Green dot C4's from the mid 60's Fords had that pattern I think. P-R-N-D-"green dot"-L
  13. G V Gordon
    G V Gordon
    from Enid OK
    Yep, my '63 Poncho is that way.
  14. brett4christ
    brett4christ
    At least on Corvairs, on PowerGlides, there was no "P", just NDLR. You had to set the parking brake to keep from rolling.
  15. blackmopar
    blackmopar
    from fallbrook
    am I missin something - typically trannies have reverse on the park side before neutral, no? PRNDL
    later PGs were NOT the second pattern you mention, but I think theyre right about it maybe for an early PG -seems like inevitable ****** work in the waitin unless theres a real reliable lockout
  16. Spedley
    Spedley
    I seen that pattern on 2 '59 Buick's a month or so ago.
  17. Dick Dake
    Dick Dake
    Studebaker Flightomatic had that.
  18. squirrel
    It was a 50s thing, very common back then.
  19. briggs&strattonChev
    briggs&strattonChev
    I believe this man.
  20. Hitchhiker
    Hitchhiker
    yep, Just had a 1962 Vauxhall (British for Chevrolet) that left the shop this morning with a powerglide (hydromatic) with that shift pattern.
  21. skunx1964
    skunx1964
    ya, early 60s buicks had the second pattern too, from what i remember
  22. plym_46
    plym_46
    from central NY
    That was the pattern of most lever selected automatics. In 64/65 the Safety Nazis were just getting started and along with telling chyrsler to do away with the push****on selector, and told everybody else to put reverse where it couldn't be accidently engaged while looking for a forward gear. Didn't want folks slapping the lever down a click or 2 or was that 3 and then stompog the gas in reverse. Some early automatics lacked the Park position also. The shifter was put into neutral and the parking brake needed to be used to secure the car from rolling.
  23. sammamishsam
    sammamishsam
    Dad had a '55 Chev 6 cyl with powerslide trans with PNDLR. I tried downshifting it on a hill one night and slid right into reverse at about 25 mph. The car survived the ordeal but how I have no idea. The PRNDL pattern was created to prevent that occurance
  24. Ahh, but the trick was that R (reverse) was the parking position. And in the cars that used a pattern like that, R was supposed to lock out above 7 mph. My Olds certainly locked R out, but grit and grime could possibly defeat this feature.
    Truth is, most automatics made before 1965 used this pattern, or one similar (prior to about '53 there was no P position). And there was NO standardisation (until NHTSA and about 1965).
    Just for one example, a Ford Cruise-O-Matic (prior to 1967, after were Select-Shift) had a pattern of: P R N D D L with the second 'D' being a white circle with a green dot. The trans worked like this: P was Park. R was Reverse. First D was second and third gear ONLY, useful for rain and snow, lowered the torque that the rear wheels saw. Second D (green dot) was first through third, intended as the usual Drive position. L held the trans in a lower gear, it did NOT limit the trans to first, but instead held the gear the trans was in, be it first or second. Manual shifting one of these is accomplished thusly: Starting in L, accelerate until you wish to shift to second; move the lever to D, then back to L after the shift. Into third - just move the lever back to D.
    And all the rest had similar 'secrets' for shifting.
    Cosmo (the TMI guy)
  25. Lstude
    Lstude
    All Studebakers had PNDLR
  26. chaddilac
    chaddilac
    1959 olds had it!!! ****s too, if you hit a big bump and your shifter is loose, it'll drop down in Reverse!!!!
  27. LOST ANGEL
    LOST ANGEL
    Thank you Cosmo, Perfect explanation. If you really want to mess them up, you could bring in Fluid-Drive to the party.-MIKE:cool:
  28. d2_willys
    d2_willys
    from Kansas
    Nope, the R is for reverse, you may be thinking HR (57 only) which meant hill retarder. 58-61 changed to GR (grade retarder)
    Turboglide: PRNDHr, PRNDGr
    Buick Flightpitch: PRNDG
    PRNDL (58 and up Powerglides, 64 turbo hydramatic 400.
    PNDLR came from some of the early GM transmissions:
    -pre 58 Cast Iron Powerglides
    all twin turbine Dynaflows.
    Buick dual path dynaflow
    Early Hydramatics were:
    NDLR (Single range Hydramatics)
    NDSLR (Dual range Hydramatics)
    PNDSLR (Dual Coupling & Roto Hydramatics) used in Olds and Pontiacs
    PND4D3LR (Dual coupling used in Cadillacs)
  29. The Dual Coupling was a 4-speed and could be shifted to any of the 4 gears, is why. My '60 Pontiac had D indicated as two positions on the dash, but I can't remember if they marked it D4D3 or some other way. I do know if you left it in third it would shift to drive by itself - at about 70.
  30. 5window
    5window
    Ah, that's because I am an idiot who can't type and won't proofread. Should have been "PRNDL":)
