whats this tool?
Discussion in 'The Hokey Ass Message Board' started by bct, Jan 1, 2012.
  1. bct
    bct
    something says lifter puller,, but that is a guess, thanks all.
  2. 40Standard
    40Standard
    from Indy
    any brand name on it ?
  3. badshifter
    badshifter
    Looks like fingers.
  4. bct
    bct
    thanks, no name on it at all. the collar on the shaft slides and there are br*** tabs that retract at the tip.
  5. patrick66
    patrick66
    Looks like some sort of handheld bit driver.
  6. roundvalley
    roundvalley
    Looks like a slide hammer idea. Lifter puller??
  7. Willy301
    Willy301
    Small seal puller?
  8. Hello, ... I think we have a winner!!!
  9. 52Poncho
    52Poncho
  10. It's the world's largest clecko...:D
  11. Kinda fuzzy pic, but I think it's an extension cord... Happy New Year, bct :)...
    Hey, you never gave me an answer on that front axle you're lookikng for!!!
  12. Homemade44
    Homemade44
    There was a tool very similar to that to help line up heads on flat head engines. There were stepped inserts with a hole in the center. You put the small end of the insert into the threaded hole. The section ahead of it was slightly larger so the hole in the head for the bolt fit over it. This aligned the head. You started the other bolts and then inserted the tool in the inserts and pulled them out.
    Your tool is probably for something like that.
  13. zephyrV12
    zephyrV12
    from pomona ca
  14. GREASER815
    GREASER815
    It's a lifter puller, usually they are hard to get out. Probably can change the tip and use it to pull those stubborn valve cores also.
  15. tofords
    tofords
    It's a deburring tool to debur a blind hole, one you can't get to from the other side. Frank
  16. speedfreek155
    speedfreek155
    Doesnt look even close to my lifter puller not that
    It cant be. Almost look like a "frozen" bolt remover
    That you hit with a hammer to "wake up" those stubborn bolts
  17. tb33anda3rd
    tb33anda3rd
    almost looks like the tool that "sets" door handle escutcheons. or maybe for grommets?
