Technical Whats up with the search function?
Discussion in 'The Hokey Ass Message Board' started by Russco, Dec 4, 2015.
  1. Russco
    Russco
    from Central IL
    Maybe its only me, but I haven't been able to find **** since the format changed when doing a search. I'm looking for some specs or info on a K88 ch***is. So I go to the search icon and click it. In the search for box I put "K88", check the "Search ***les only" box. Leave the"posted by Member" box blank. Put July 4 2009 in the "newer than" box. Search results are 4 pages of random threads and not one with K88 in the ***le or anything even remotely close, and none going back more than Tuesday of this week. So whats the deal? Am I doing something wrong or does the search function just **** that bad now?
  2. gimpyshotrods
    gimpyshotrods
  3. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
  4. Russco
    Russco
    from Central IL
    No, Ive seen that one but thanks. There were a couple others I've seen too over the years that had some specs and other info in them. I was looking for any others though. When you do a search are you finding any more?
  5. TailDrag
    TailDrag
    I generally find most forum searches to be less than efficient. Instead, I go to Google and search a forum via their search engine. Have you tried that? Just search for something like "jalopyjournal.com K88 specs" and see if that isn't more fruitful.
    volvobrynk, bct and loudbang like this.
  6. cretin
    cretin
    Yea, I think the search function ****s. There is the Google tab that works a bit better, but I have a hard time finding specific threads I'm looking for too.
  7. gimpyshotrods
    gimpyshotrods
    If I un-check "Search ***les only", I get more.
  8. RICH B
    RICH B
    Put K88 in parenthesis, like this: (K88). This keeps the search tight on K88 instead of its components.
    Search terms with numbers work better this way. To get better results on most searches I also go to the advanced (more) page and select either "recent" or "relevant" as the case may be.
    willbe and loudbang like this.
  9. Russco
    Russco
    from Central IL
    The Parenthesis did the trick. I found the thread I was looking for. Thanks Rich B
  10. RICH B
    RICH B
    Good to hear that it worked for you, and I really don't know how to spell "parenthesis"; had to google it.
    Russco likes this.
  11. I just google what I want to find and then include the letters H.A.M.B. on the end.
    I can't make the search function work on the new format either.
    volvobrynk likes this.
  12. bct
    bct
    I find if i google a set of terms , jalopy journal always comes up . At the bottom of the list it asks if you want "more from jalopy journal" . Always works.
