1952-59 Ford What's wrong in this pic?
Discussion in 'Off Topic Hot Rods & Customs' started by DIYGUY, Apr 7, 2017.
  1. DIYGUY
    DIYGUY
    from West, TX
    IMG_1694.JPG For sale at LSRU. Why does hood not fit grille?
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    1955 Hood on a '56, the 1956 had a peak in the center. ;)
  3. DIYGUY
    DIYGUY
    from West, TX
    I guessed maybe a different model but I KNEW someone here would know!
    JeffB2 likes this.
  4. 56FORD390
    56FORD390
    Grill seems to be pushed out at the top. I do not believe that the 55 hood had the bullet on it. It was smooth. Made it easy to "shave" the hood by swapping to a 55 on the 56. Did that back in the day when 55 hoods were all over the place. Not so much today.
  5. dodg66440
    dodg66440
    My guess is that car suffered some collision damage. Nothing fits like it should. Look at the gap between the grille and parking light housings, somethings definitely not right.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Enjoy the pictures and the music!
    DIYGUY likes this.
  7. bobss396
    bobss396
    First thing wrong... the car is not in my driveway!
  8. 55Brodie
    55Brodie
    That is a 56 hood. The grill install looks wonky to me; like it is possibly bent.
  9. 56longroof
    56longroof
    So, do the 55 and 56 hoods have the same profile? I never noticed before. I hope their the same. I just picked up a set of 55 hood and fender trim to put on my 56 when I get my tube grill.
  10. Dobie Gillis
    Dobie Gillis
    '55 & '56 hoods have the same profile. The hood ornaments are quite different; the '55 ornament is flush mounted while the '56 one sits in an indentation in the hood. Not sure if there's a difference in the latches/latch supports.
  11. 56longroof
    56longroof
    Thanks again Dobie. I was hoping they are the same.
  12. 55Brodie
    55Brodie
    The 55 has holes punched on the leading edge for stainless trim, but will bolt on to a 56 no problem.
  13. raceron1120
    raceron1120
    Wiper blades are missing, left/driver side outside mirror missing, right side mirror not correct for model year. Paint separation below headlights not centered. I don't think the hood is incorrect, it and the grille might just need some tweaking/adjusting to reduce the center gap. Mine has a similar gap too, but is much less than the one shown above. Mine:
  14. DIYGUY
    DIYGUY
    from West, TX
    The hood seems to fit the body well, just not where it meets the grille. I too think the grille or under structure must be the culprit. SURELY Ford did not stamp out two different hood shapes.
