What's wrong with picture
Discussion in 'The Hokey Ass Message Board' started by jimvette59, Feb 10, 2012.
  1. jimvette59
    jimvette59
    Please help. I installed new bushings and new king pins and they are proper , no play. What is you opinion about the king pin inclination. Looks like 7/8" in 27" it could be more with the proper measurement. I think the axle is not bent right.
  2. rottenleonard
    rottenleonard
    I would heavily suspect the dropped axle not being correct,
  3. millersgarage
    millersgarage
    When measuring, make sure the wheels are dead straight ahead, if they are turned the caster will effect the camber
  4. I see the motor is in. Are all the other heavy bits in place?
  5. I would put a level on the floor along side the L square.
  6. 51 MERC-CT
    51 MERC-CT
    Check the kingpin inclination at the kingpin. As I recall it should be about 8 deg.
  7. impalamark
    impalamark
    x2 pretty meaningless with out the level most garage floors have a slope
    and that my be part of the equation
  8. DD COOPMAN
    DD COOPMAN
    Working with the dimension given (27"), 1°= about 0.47124" (almost 1/2"). In other words, you're looking at just shy of 2° POSITIVE camber. DD
  9. styleline
    styleline
    from so-hol
    where,s the beer
  10. 26 roadster
    26 roadster
    If all opinions fail,,,,get it aligned...the sure cure
  11. jimvette59
    jimvette59
    Leonard I think you got it right. Is there a shop in M***. Conn. NY area that rebend this axle.
  12. brad chevy
    brad chevy
    You got any pics of the whole frontend with the wheels straight ?
  13. Internet
    Internet
    if the measurements stated above are correct ( i did not check) 2 degrees positive camber is what henry originally intended for bias ply tires. radial tires are recommended to have 0 degrees.
    just went through this all after i dropped a few axles, i use an angle finder on the backing plate mounting surface on the spindle.
    with the wheels dead straight.
  14. After the car is finished and the final weight is on the axle, get it aligned by a reputable front end alignment shop. Adjusting the camber of a beam axle is no problem for any alignment shop that handles medium duty trucks with beam axles.
  15. jimvette59
    jimvette59
    Brad Chevy I could post pictures tomorrow. The drivers side is more like 1/2" and looks right. Thank you every one for all the information and I will get it straightened by a H.A.M.B. Alliance Member.
  16. 51 MERC-CT
    51 MERC-CT
    So long as the floor is flat it could be out of level 45 deg. and the readings would be the same.:)
