What's wrong with this car?
Discussion in 'The Hokey Ass Message Board' started by willowbilly3, Aug 28, 2004.
  1. willowbilly3
    willowbilly3
    from Sturgis
    Every time I look at this car it just bugs me. And it isn't the basic style so much as it is a total screw up the builder made. What is it?
  2. The37Kid
    The37Kid
    Steering drag link or rear radius rod?
  3. The Harpoon
    The Harpoon
    wheelbase=too long
  4. Aushotrods
    Aushotrods
    Been stretched at the front and the rear section of the cabin has been lengthened. Dunno why they stretched the frame? The bed doesnt look too flash either, but I bet the owner/builder loves it.
  5. jalopy43
    jalopy43
    The nose is too long. Room for two small blocks! The bed is too tall,what's it hiding? a 30 gallon gas tank? I dunno, it's easy to pick on though.
  6. willowbilly3
    willowbilly3
    from Sturgis
    All the things you guys mentioned plus the baggy top and the dorky wheels but the drag link was the thing that really got me. And if you see the front view on the ebay it is just as bad with a panhard bar that runs on an angle with this realy busy coilover set up.
    I can find something out of place on about 90% of the ebay rods but this one was like seeing a blond out of the corner of your eye but when you take a look she has a huge nose and one boob three times bigger than the other.
    Like Baskerville said, if the hairpins/radius arms and the drag link aren't parellel to each other and the ground it throws off everything else you have done. His sense of balance and proportion for a basic rod were impeccable and timeless. Even a small point like the radiator setting an inch too high can just mess up the whole look of a car.
  7. Gas_Tires_Oil
    Gas_Tires_Oil
    The engine is set too far forward and that's where the problems started with the longer nose. You see too much of the trans.
  8. Rusty
    Rusty
    I think it looks sweet but I beleive in the front axle was moved back and put in the stock position of a model a it would pull the wheels back to were they need to be. The draglink apears fine yo be based on the corvair box that he is running. I like it though. What is it under on ebay?
  9. WHICH SCREW-UP? [​IMG]
  10. Lets see if I can narrow it down........EVERYTHING [​IMG]
  11. SanDiegoJoe
    SanDiegoJoe
    the bed is too high.
  12. fab32
    fab32
    Looks like he started to build a T-bucket then changed his mind.
    Frank
  13. Flat Ernie
    Flat Ernie
    Tech Editor
    Proportions...
    ...all wrong
    Pretty much what everyone has said already - wheelbase, front end, bed, cab, top, wheels, draglink, etc, etc.
  14. Flexicoker
    Flexicoker
    and the colors, orange and yellow [​IMG]
  15. BELLM
    BELLM
    All of the above, give it to me, I'll part it our, or maybe put a hot GMC straight six in it. Or 2 v-8s.
  16. 47lincsled
    47lincsled
    There is a purple closed cab truck up the road that looks just like that,when I first saw it I tried to figure out what was wrong,basically everthing,would be a good starting point.
  17. Paul
    Paul
    Editor
    needs adjusting everywhere..
  18. front end is too long, back is too short(both heighth and length wise) and the wheels look like they belong on a trailer....
    Greg
  19. willowbilly3
    willowbilly3
    from Sturgis
    But that drag link!! can you imagine the bump steer that thing must have.
  20. Morrisman
    Morrisman
    from England
    Is it my baggy eyesight or does it have real short hairpins at the front?
    Also, if he put the drag link up where it looks like it was meant to be, reversed the steering arm, he might have a hell of a problem turning corners with the wheels going the wrong way [​IMG]
  21. Dunno. Kinda looks like someone messed up building a kit car. It's weird though... there was a new guy about a week ago that posted shots of his car that actually looked something like that, but it was all homebuilt and in black. For some reason his car didn't look off like this one.
  22. hotrod54chevy
    hotrod54chevy
    from Ohio
    i think it looks silly stretched out like that..and i'd change the wheels.
    creepy
  23. Deuce Rails
    Deuce Rails
    Raising the grille would help a lot.
  24. helrzr1
    helrzr1
    from Iowa USA
    It could be just me but is the frame kinda bent or shape like a 32 perhaps, but instead of putting the wheels in the curve they kicked them way out, left that curve just sit there empty.... maybe its just the pic, or my bubbled computer screen.. Another excuse for a flat screen moniter!!
