Projects Whats your winter project/projects?
Discussion in 'The Hokey Ass Message Board' started by n847, Oct 22, 2012.
  1. Chopp'd49
    Chopp'd49
    I am going to try to fix this mess... Then I'll be able to finish the taillight install, add 55 olds headlights, build a grille surround, finish the chop, rebuild the small block and hit the road....
  2. 40StudeDude
    40StudeDude
    Wow, how'd you get that car to stick on the ceiling...??? Getting it down from there might present a challenge...and then it'd be a real "mess"...
    R-
  3. JB Weld
  4. n847
    n847
    Yep first things first I'd get that sum bich off the ceiling! It'll all be down hill from there!
  5. Rich Wright
    Rich Wright
    Rebuilding my roadster.
    I have a pretty good start on setting up a new ch***is.
  6. ModelAPunk
    ModelAPunk
    from Buffalo NY
    V-8 - 4 Speed Swap in my 53 Chevy. Hopefully some kind of paint too!
  7. Poesrodandcustom
    Poesrodandcustom
    from Kentucky
    First project is clean the shop out (again) so I can get my new project in. Hopefully have a driver by spring.
  8. Clean up parts and get 'em ready to sell.
  9. olscrounger
    olscrounger
    do another 40 coupe--will blow apart after holidays-expect done minus uph by mid april if funds hold out
  10. Freeberg
    Freeberg
    Get this thing rebuilt and painted!
  11. My neck hurts! ^ ^ ^
  12. Gene Boul
    Gene Boul
    1. Finish the shed so that I can move the "lawn" stuff out of the garage.
    2. Finish the outside carport so that I can move the good trailer out of the garage
    3. Finish the 52 F1 PUP
    4. Finish the 38 coupe'
    3. Start on the 50 vert
    The older I get the better I was...
  13. heres my project for the second year in a row!
  14. fastrnu
    fastrnu
    from shelton,wa
  15. ct1932ford
    ct1932ford
    This was it but it's running and finished now. If the body sells it will be coming all apart. or entire car is for sale.36K I guess I need another project:cool:
  16. cakes
    cakes
    Swapping the ch***is on my 57 gmc truck (late model 4x4 to original) and working on the 54 210 g***er, hopefully have it in color soon!!!
  17. Quintin
    Quintin
    finish my 39 chevy
    fixing alot of problems that it had when i got it
    new hood, dash, seats, and painting the whole thing
  18. glendale
    glendale
    finish this for the new owner by mid jan.
    then get this road worthy and change the color for summer.
  19. n847
    n847
    Glad to see you still get to see the Mopar through to the finish...Cant wait to see that new project under way...looks super solid!
  20. 41 C28
    41 C28
    First thing is to get shorten finger healed up and then get to work on my A so I can get it on the road this summer.
  21. Bcometfx
    Bcometfx
    from NC Indiana
    Workin on my new 30 A sedan. Started choppin the top yesterday. Gonna be a budget build. Leave it a banger chop it redo the interior and a quick paint on the lower side. Just gonna put it in primer for now.
  22. low-n-slo54
    low-n-slo54
    Now that I have a decent place to work, it will be work on the front axle and engine for the '31. Have to wait until march to pick up my frame and body from MN and KS.
  23. n847
    n847
    Bcometfx...That A is bad ***!
  24. bradshaw
    bradshaw
    from ontario
    Hope to get more done on my Fargo
  25. flatout51
    flatout51
    Getting my Model A rollin... Mid to late 40s style 28 sedan...
  26. glendale
    glendale
    thanks man it is and it willl make for a great road trip car!
  27. Bcometfx, do you have pics of the chop you did? How much was taken out? Looks great, keep motovated!
  28. fab32
    fab32
    When I get the mechanical to hydraulic brake conversion done on my '38 I'm going to try my hand at a fibergl*** project. UP to now a Corvette is the only gl*** transportation i've ever worked on but after aquiring a new gl*** '29 roadster body CHEAP I'm planning on throwing all of my extra parts, that just clutter up the shop, at it and see if I can make a cheap hot rod.
    Frank
  29. Finish building the 225ci slant 6 for my '63 Dodge 330. Also have trans , front suspension, breaks and mics to finish as well. Car has been sitting for 5yrs and stuck in the garage for 1yr. Would like to have it running by spring 2013.
  30. n847
    n847
    Damn straight and in your neck of the woods (or lack there of) there's some hella shows to road trip to!
