Projects Whats your winter project/projects?
Discussion in 'The Hokey Ass Message Board' started by n847, Oct 22, 2012.
  1. flathead okie
    flathead okie
    this
  2. das858
    das858
    My winter project is a front engine dragster build, so far the ch***is is fully welded, rear end housing narrowed and mounted, block mocked up in ch***is and motor mounts made, fuel tank mounted. I'm waiting for the front axle and rear spool and axles to arrive now.
  3. Russ B
    Russ B
    want to get this one rolling and with a good primer coat on it.
  4. Paul
    Paul
    Editor
  5. 1971BB427
    1971BB427
    from Oregon
    Already started and finished some of my winter list. After nearly two years of driving my car, I finally built carpets for it and put them in recently. Also while the seats were out I rebuilt the seat bases to lower the seats 1.25" for a better position. Finally got all the parts built for my chute release and got it in this week. And got the new finned covers built and installed on the trans and rearend.
    Still need to do a few more small things, and lots of cleanup from 6,000 miles I put on it this summer. Couple little engine mods, and a short trip back to the paint shop to fix a big paint chip I got in the cowl.
  6. Ha Ha!
    Hey Paul, I like your Bibendum. [​IMG]
  7.
  8. Paul B
    Paul B
    Doing up a 53 Chevy sedan delivery
  9. scootrz1
    scootrz1
    from usa
    making new door , kick , and back panels. already put steel wheels on it , got a hot rod steering column to put in to take out tilt column . took 3 years to build been on road since august so changing stuff this winter .List really not to long. also planning on getting next project in garage , Hot rod truck with a flathead in it
  10. Shane Spencer
    Shane Spencer
    My apache, dropped right around 11 inches over stock, no bags
    Sent from my DROID device using the TJJ mobile app
  11. Careful with that. We wanted to get away from NH Winters 2 years ago so we bought an old Winnebago & spent that Winter on the Gulf coast of Alabama. Were so spoiled with avoiding the snow & bitter cold that we decided we had enough. I was born in York ME and lived most of my life in NH. Last October we packed up everything we owned, bought a house in East Tennessee and never looked back. Best thing we ever did. My project for this Winter is to have a 30x40 garage built complete with a lift and then look for a new project car to work on. This area seems to be damn near perfect as far as I'm concerned. About the same Summer weather as NH but very mild Winters. Alabama was nice but most of the guys we talked to who live there year round told us the Summers can be brutally hot. There are alot of old cars & trucks around here, cruise nights going on all the time, an hour to Pigeon Forge & Gatlinburg, etc. I wish I had done this 20 years ago.
  12. n847
    n847
    Finally getting something done!
  13. jazz1
    jazz1
    The Sedan Delivery,, the wife seemed to think I needed a project and so she bought this thing. I would have been quite content to spend the winter in the garage sipping scotch and stoking the fire however I am starting to see the car as being even more practical for road trips as far as room for swap meet purchases and it too can haul a trailer.
  14. biggeorge
    biggeorge
    Here are my two winter projects
  15. Jason455
    Jason455
    40 ford, airride, non hamb friendly power.
  16. ct1932ford
    ct1932ford
    Well it is another year now :eek:and here is this winter's project!:cool:
    http://www.jalopyjournal.com/forum/showthread.php?t=845122
  17. Russ B
    Russ B
    I posted on this thread about a year ago and it took about a year to what I had planned mostly done. This winter I hope to complete final mockup and get it running before teardown for paint.
  18. Boones
    Boones
    from Kent, Wa
    Priority is to get the 31 PU together so I can sell it. then I will work on putting my LS motor and trans in the 51 and do some rust repair in the qrt panel.
  19. hoodprop
    hoodprop
    Things to get done to the hotrod.
    ---Rewire
    ---Install Bench Seat
    ---Install Gl***
    ---Reinstall Intake
    ----Reinstall Rear Axle
    ---New Tires On the Rear
    ----Make a new wood Bed.
    And what ever else comes along the way.
  20. n847
    n847
    Glad to see this thread resurected for the 2013-14 winter. Last winter was relatively successful even though it turned to spring before the jobs were done. My motivation is coming back so my plans are coming together...
    Run new trans cooler lines
    Re gasket trans
    Flush trans
    Adjust my gennie shifter linkage
    New exhaust donut gaskets
    Oil and filter change
    Clean and touch up exhaust manifolds
    New spark plugs and tune up
    Replace the electric fuel pump lead with a nice new one.
    Replace my stock cut coils with the aerostar coils I've had since Christmas last year
    Then hopefully front upper shock mount relocation and new shocks in the rear (maybe air?)
    Those are all of my highest priorities but some of them will be money dependant.
    Good luck to all you guys!
  21. 41 C28
    41 C28
    My motivation is returning also and Happy Thanksgiving .
  22. Seats back in the 57 150.........original shifter, correct carpet and door sills in the 66 Nova SS, build the 66 L-79 Nova engine and install existing LT-1 in 57 truck, get 55 g***er project on rotesserie, build mezanine in pole barn for storage. that should keep me busy. :eek:
  23. RainierHooker
    RainierHooker
    from Tacoma, WA
    This winter is (hopefully) when I will finally get the studebakers back on the road, and knock a few items off of the tub's list of to-do's. That means...
    ...for the '52 Champion:
    -finish the Commander brake-conversion
    -put in an exhaust system of some flavor
    ...for the '59 Truck:
    -new wheels 'n tires
    -brakes
    -get the 4-barrel intake on the motor, with a new carb
    -figure out why the ****** is whinning when in park
    -fix the above issue, however I need to
    -get the bed pulled off, and straitened, and put back on
    -and when all those ducks are in a row, sheetmetal, sheetmetal, sheetmetal
    ...and for the Phaeton:
    -finish the wood kit install
    -make the doors close pretty
    -sanding, and blocking, and primer, and sanding, and blocking, and primer...
    Guess I've got a full list. Time to get to it.
  24. tommyd
    tommyd
    from South Indy
    Call Scarebird and get some STOPPING ability! New toprail weather strip. Some kind of f.m. radio and fix a driveline vibration.
  25. philly the greek
    philly the greek
    from so . cal.
    I going to make the flames disappear and change the cam .
  26. hd1084
    hd1084
    I'm going to get rid of my Hot Rod Primer look and paint my coupe Hugger Orange and change out the wheels.
  27. n847
    n847
    Good to hear your getting back atbit 41c28 and happy holidays to you!
    Philly that's a wicked little roadster with or without the flames!
    You guys are all much more productive than me!
    Sent from my SAMSUNG-SGH-I747 using H.A.M.B. mobile app
  28. raymay
    raymay
    Make a list and hopefully complete a few items on my 37 and 56 Chevy current drivers.
    Finish up more of the fabrication on my 66 Malibu wagon 2 door conversion project.
    Install steering in a jointly owned 32 Ford Coupe project.
    Continue our build on Rick's 33 Plymouth Coupe.
  29. petew
    petew
    from Mebane, NC
    Working on getting my 57 long roof done....
  30. louisb
    louisb
    My winter project will be my first Flathead rebuild:
    2013-11-30 07.57.59 by louisfbrooks, on Flickr
    8RT block
    EAB Heads milled for compression
    3 5/16 bore X ?? stroke. Still looking for a Merc crank but if I can't find one I will go with an aftermarket stroker.
    L-100 cam
    2x2 Offy setup w/ 97s
    Still collecting parts but hope to do final ***embly in the Spring. Then I have to find something for it to go in. That will be next winter's project. :D
    Thanks,
    --louis
