Wheel adapters
Discussion in 'The Hokey Ass Message Board' started by failed_ethics, Sep 26, 2003.
  1. failed_ethics
    failed_ethics
    Are wheel adapters safe to use? They seem like an easy way to change the bolt pattern. Some people say they'll kill bearings and others say they've been using em on a car for however long and it's still fine. What do you all think?
  2. Paul2748
    Paul2748
    I ran them on my 302 Ford powerd Model A for about ten years. Never had a problem with them. Ran them for about five years on my 48 Ford, same story. They were brand name products, no junk stuff
  3. onelow48
    onelow48
    from Maryland
    I've worked in the wheel business for over 10 years. There
    are good and bad ones. It's just like anything else. Its
    all how you go about it. I ran them on my last 3 rides no problems. The bearing ware can becused by using incorect
    lugs. Once you have a adapter your wheel is no longer hub
    centric. By useing the right lugs you can center them with
    thin wall et style lugs. Excaliber is one off many companys who offer everthing you need.
  4. old beet
    old beet
    I used them for 15 years on my F-1, had to tighten them up a couple times, I think the good ones are safe....OLDBEET
  5. failed_ethics
    failed_ethics
    any clue where I can find excalibur merchandise? or any other good companies? big help guys, thanks
  6. jdubbya
    jdubbya
    Discount Tire can order good wheel adapters, billet and strong, and I am sure that they are accesable to other tire venders. I have a freind in the biz at Discount Tire in Fenton, MI. If all else fails give him a call to inquire about them, he can ship them anywhere via UPS. His name is Pete McVannel, (810)629-4764, He will be able to hook you up, he is running these on his t-bucket.
