1952-59 Ford Wheel and tyre size question
Discussion in 'Off Topic Hot Rods & Customs' started by 4t6ford, Sep 28, 2011.
  1. Hey Guys n gals ,
    need some input on what size wheels and tyres you are running under your '55-'56 's please .
    Here's the story , friend of mine has just bought a '56 Vicky , it is on stock rims with narrow whitewall . he wants to get a set of early 5 spokes ( torq thrust or similar ) and is thinking possibly running 15x6 on the front and 15x7 on the rear ( I already told him he wont get any bigger than 7" under the rear ) .
    The Vicky is stock hieght at present but will get a very mild drop ( prob 2" all round ) and is already fitted with a 9" rear out of a '57 fairlane .
    Your thoughts and suggestions please .....
  2. the-stig
    the-stig
    I'm running 15x8 with 235/60's all around but I'm running a 98 Blazer rear end, 4 inches narrower than stock.
  3. dragonknucks
    dragonknucks
    If he wants to go with 15x7 in the rear and 14x7 in the front, let me know. Shipping would be hell, but I have some Cragars that Im still trying to get rid of! ;)
  4. Retro Jim
    Retro Jim
    You should jack the car up like you would do if you have to change a flat and measure the distance between the brake drum and inside of the fender . That way you will know how wide of a tire you can go with so you can change a tire when need be . Then figure out the backspace and go from there . Can't use a tire too wide if you can't get the tire up between the fender and brake drum . Now if you are planing on adding the lower blocks make sure you add the block first , then take the measurements .
    If you have some friends with wider tires and wheels maybe they will let you try and see if they will fit your Vicky or not .
    Jim
  5. Thanks for the input so far guys . Dragonknucks you're right shiping could kill the deal :eek: . Jim , I follow what you're saying ... problem is this car is still in the USA and as my darling wifeys car here has an 8 inch out of god only knows what under it I can't use it as reference either :eek: . ... She reckons I lie about most measurements anyway ...
  6. fxcomet
    fxcomet
  7. DIESELCHUCK
    DIESELCHUCK
    from MASS
    wow i love that look! i think 18"s would look great also
  8. Vicky
    Vicky
    from Norway
    Hi!
    I have 17x7 in front and 18x8 in the rear! Great!
  9. Vicky
    Vicky
    from Norway
    Hi again!
    Forgott to say it cut 1 and 1/4" turn in front coil and 2"drop in rear!
  10. fxcomet
    fxcomet
    What's your backspace measurement on those?
  11. Vicky
    Vicky
    from Norway
    Hi! FXcomet
    The rear 18x8 with 4,5" backspace. C5 CHROME WITH BULLET CAP and boltpattern 5x4,5
    And 17x7 in front
  12. DIESELCHUCK
    DIESELCHUCK
    from MASS
    i WONDER IF THAT WOULD WORK ON A 56 MERC MONT.?
  13. brassspike
    brassspike
    Rears are 17x8 and 30mm offset I am running 255x 45 tires with no clearence problems. Actually I have nice room to the inner fender. I'm also on a 9" Versalles rear though.
