Wheel Bearing number Q
Discussion in 'The Hokey Ass Message Board' started by C9, May 22, 2009.
  1. I'm running re-pro 37-41 Ford spindles and they take the standard Ford wheel bearing size.
    I'm wondering if the 46 Fords use the same wheel bearing?
    Curiosity mostly, but my pal runs a 3" dropped axle 46 with Camaro disc brakes up front and it would be nice if my bearings fit his spindles.
    Just in case, ya know?:D
  2. choppintops
    choppintops
    The Ford inner bearings dont fit the camaro hubs, thats why they use spacers.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    28 to 48 as I recall all use the same inner and outer.
  4. Thanks guys.
    A couple of good answers.
    Which means, one pal - with roadster and 46 Ford drum brakes can borrow my spare and maybe my pal with the 46 can use one of the bearings.
    Which - Choppintops - I'm translating as, an inner bearing with different part number
    from a Ford inner is used with a spacer to be able to use the Camaro brakes on the Ford spindle.
