wheel bearings cheap/
Discussion in 'The Hokey Ass Message Board' started by 55 gasser pickup, Jan 12, 2011.
  1. 55 gasser pickup
    55 gasser pickup
    from utah
    ANYONE KNOW WHERE TO GET THEM FOR A 55 second series pickup.They are for the front.I havent found any under 140 bucks.thats for a whole set.please help!
  2. nummie
    nummie
    140 for a set? sounds pretty cheap to me. thats 4 bearings, so 35 a bearing? for a 56 year old truck. Just make sure they are timkens or fafnirs for those prices.
  3. highboy_04
    highboy_04
    from Kansas
    140 for the whole set? so both inner and outer bearings for both sides? 140 isnt a bad price if its all 4 bearings. do you need them all or just one?
  4. 55 gasser pickup
    55 gasser pickup
    from utah
    really i just need an outer one.I found one at napa today for $62.and its a ball bearing orig**** style.I want to up grade to roller or tapered whatever you prefer to call them.the set i found was on egay all roller.im just trying to get buy really until i get front discs.
  5. nummie
    nummie
    napa should be able to get the #s of the original ball bearing, look up the specs of it (OD, ID, width, and load range) and match a tapered roller to that number. They have the books to do this, but finding a desk jockey at any modern parts shop willing to cross-reference #s is hard. Heaven forbid they open a book instead of looking at a screen!! If your Napa wont do it, go somewhere else. find a "local" shop, they always are great with that kind of stuff, then go there for all your parts, no exceptions.
  6. 55 gasser pickup
    55 gasser pickup
    from utah
    Brothers has the one's i want eventualy they are just to much for me right now.i was told the orig**** bearing maker is out of buisness.the name on the old bearings is new departure ha ha! no bs.
  7. Buy bearings at a Bearing store,,,,,,should be better prices,,,,
  8. carcrazyjohn
    carcrazyjohn
    from trevose pa
    B101 and b102 Those bearings are expensive ,I paid around what your paying ,Also checked online ,Post in the wanted section ,You might have some luck ..........
  9. Dale Fairfax
    Dale Fairfax
    What is funny about "New Departure"? They were one of G.M.'s divisions and their source for ball bearings for many years. Hyatt was their roller bearing division.
    Most bearing houses that I've dealt with do not/can not supply the caged New Departure style ball bearing (It was also used in bicycle hubs and Saginaw steering gears). Best bet is some obselete parts supplier.
  10. Dale Fairfax
    Dale Fairfax
    Just as a shot in the dark, try Authentic Automotive at either 972-552-2221 or rpo324@sbcglobal.net. I've bought New Departure style bearings from him for steering gears.
  11. boogeracng
    boogeracng
    from Eureka,MO
  12. BISHOP
    BISHOP
    Dont go through an automotive chain store, Go to a bearing store. They can get any bearing on the planet at a fraction of the cost.
    Motion Industries is who I use.
  13. squirrel
    Yeah, ball bearings **** That's why a 55 year old truck still has the original 55 year old New Departure bearings in it....
    what number on the outer bearing? The last two digits should tell you the part number, usually either B01 or B67
    Bearing stores don't sell specialty automotive wheel ball bearings that I know of. It's an auto part.
    rockauto.com has them but you need to know what the number is first
  14. Dale Fairfax
    Dale Fairfax
    Amen! And that's what I was trying to say: Bearing stores don't do automotive ball bearings.They can probably do the roller conversion parts but why would you?
  15. mj40's
    mj40's
    I never could come up with the bearings to convert my 54 Chevy ball bearings over to rollers. I heard there used to be a conversion.
  16. lorodz
    lorodz
    not sure if its the same but i have a 1956 bel air i took the old ****ty looking roller ball bearing out and replaced them with the seal type bearing from a 62 impala they work great no more vibration and there seal completley good luck oh and they were way cheaper
  17. Saxman
    Saxman
    Uh, the original ball bearings were in the truck since 1955? Are you hoping to get greater longevity out of the tapered roller bearings? If you pack those ball bearings right and maintain them, they'll outlast you, believe me!
    Beside, ball bearings are more "traditional" :D:D:D
  18. You might try Northwestern Auto Supply 800-704-1078,,,,LOTS of NOS stuff, in MI..
  19. gas pumper
    gas pumper
    I got a tech thread about this I did a couple of years ago. No machining of hub or spindle. Simple spacers and off the shelf bearings. And orig wheel seal. I actually done the conversion about 10 years ago, maybe 8?. And no issues since. No repack yet but a couple of minor adjustments on the spindle nut. Mostly highway miles on this car, about 15,000 on these so far.
    If you have access to a manual lathe you can do this and sell your old ball bearings to a Corvette restorer :D for a lot more than the new parts cost.
    Frank
  20. DERPR30
    DERPR30
    from HARVEY LA
    try motion industries a lot of offices or online
  21. 55 gasser pickup
    55 gasser pickup
    from utah
    thanks fellas.i tried motion yesterday and they said they would look and call me back i didnt hear anything from them.so i called them and they said they had to get them from the east coast.so i think i would get stuck with the shipping of course.i will try rock auto and northern supply thanks again
  22. AllSteel36
    AllSteel36
    There is a direct outer bearing (timken) that fits the spindle pefectly, but inners require a sleeve and a different seal.
    Somewhere I have the info, PM me so I don't foget to look for it.
    PS...140 for the ball bearing set is probably about the best you'll find for them.
  23. 55 gasser pickup
    55 gasser pickup
    from utah
    good news! i just found the new style ones from cpp(cl***ic performance parts)for$100.$110 with the ride i guess i'll save up for them.thanks for all the help
  24. oldolds
    oldolds
    Try a bearing store, they have automotive bearings. A bearing dosen't know what it is in. Look in the yellow pages of the nearest large town or city. If you have a business name to use or tax number that you can use, like a farm number or contractor number you will get them less than half of napa price.
  25. The Shocker
    The Shocker
    You can reuse them from another truck .Just make sure you keep the inner and outer race with the bearings they were on.I have done it many times with the expensive ball type bearings.Lots of people clip these trucks and just throw the spindals / hubs away with the rest of the axle .Im not saying to use junk ,but nothing wrong with them being used .You can clean them up and 8 times out of 10 they will be fine.Btw ,if you do reuse them be real carefull not to nick the races when you knock them out of the hub ...
