Wheel bolt pattern tool?
Discussion in 'The Hokey Ass Message Board' started by d.reese, Nov 3, 2011.
  1. d.reese
    d.reese
    Anyone know where to purchase a steel wheel bolt pattern tool?
    I know there are ABS by a bunch of suppliers, but short of making one...
  2. Fordtudor37
    Fordtudor37
    Those are called a ruler or tape measure.
    I think it might be had to find one in steel, since plastic is so cheap to produce.
  3. What's wrong with the plastic ones? They always worked fine for me.
  4. propwash
    propwash
    from Las Vegas
    I have a plastic one hanging on the pegboard - had it for years - marked for everything on the planet (sans the semi tractors). Metal rusts, bends, cuts, and, as posited earlier in this thread is MUCH more expensive than good old plastic.
    Once you go plastic, you'll never go back
    dj
  5. dreracecar
    dreracecar
    from so-cal
    No big deal, Give the customer what they want. I will make you one out of steel or aluminum 5x4" 5x4.5" 5x4.75" 5x5" 5x5.5" $60 + fedex
  6. d.reese
    d.reese
    Cool, the plastic ones are the choice of you guys, that works for me! I just thought they would not work for some dumb reason. Summit is a wopping $6.69 for a ABS and one is now on the way!
    Thanks guys for your help!!!
  7. Gee was it the 60 bucks that convinced you.
  8. iammarvin
    iammarvin
    from Tulare, Ca
    $6.69!!!!!!!You must be a 1%er! :) At most good swap meets for five bucks.
  9. 49ratfink
    49ratfink
    I got a paper on from Heidts at the Goodguys show 10 years ago for free.
    I usually just use my trained eye.;)
  10. Six-Shooter
    Six-Shooter
    from Ohio
    Check out Speedway Motor's bolt circle template , item # 910-82027, $3.99. I've got one and like it.
  11. Jalopy Joker
    Jalopy Joker
    oh, he meant to say a "steal" not steel.
  12. d.reese
    d.reese
    Thanks 6 shooter:)
