Wheel bolt patterns
Discussion in 'The Hokey Ass Message Board' started by Moparhead, Dec 12, 2006.
  1. Moparhead
    Moparhead
    What's with the metric bolt patterns? Will they interchange with an older model?Say 5 x 4 3/4 with a newer metric.This metric **** is just that-----****!
    Fuzz
  2. You mean likeS-10 , Malibu, Cutl***? The wheels and bolt patterns are the same, the lugs and lug nuts are different. You have to watch the disc brake stuff though some of them don't interchange with the drum brake wheels and vis versa.
  3. squirrel
    yeah, stay away from the metric stuff, use old brakes and rearends and old wheels, you won't have any trouble. works for me.
  4. poncho62
    poncho62
    The disk and drum brake thing has always been an issue, even when it was all std threads. Like said, its only the lug/nut threads that are different.
  5. Moparhead
    Moparhead
    Yeah. I guess I have to make sure the holes in the wheels are large enough to accept the stud diameter.If it is they should be ok.
    Fuzz
  6. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Probably not, although some will say a 4x100mm. (common to VW a**** others ) is the same as 4x4 inch, but 100mm is actualy 3.94. Maybe close enough (?)
    4.75 is 120.650 mm which sounds kinda oddball (?)
  7. Moparhead
    Moparhead
    I'm using an 89' S10 subframe and rearend on my 50 Coronet.They appear to have metric studs/nuts.I guess I shouldn't have a problem.
    Thanks for the info! Fuzz
  8. squirrel
    normal chevy wheels fit on the S10, just make sure the nuts match the thread of the stud, and the shank matches type of wheel you're using, tapered for steel wheels, etc.
  9. You really need to be sure. I've found a 5x110 (120mm??) that was very close to 5x4 3/4, but not close enough to work.
    Check closely.
    Cosmo
  10. The GM Lumina sized cars with 5 bolt wheels are pretty close to small for 5 on 4.5". Maybe good for rollers.
  11. Moparhead
    Moparhead
    I'm going to the boneyard Saturday.I've got a bolt pattern gauge,but it doesn't have metric.I wonder if I can replace the metric studs in my axles and rotors.I've got a big box of new chrome acorn nuts in several different styles I bought cheap at a swap meet.If I find a matching set of wheels,I'll find an S10 and see if they'll fit.
    Thanks again, Fuzz
  12. Lug nut taper may also be different on different applications. Your wheels will come loose eventually if the tapers don't match up.
  13. Moparhead
    Moparhead
    Didn't think about taper.Now I've got a whole ****load of things I've got to consider.Damn,I hate when that happens.Too much to think about tonight.3:00 A.M. alarm is not too far off.Later
  14. squirrel
    you don't really have to worry about the taper
  15. You don't have to worry about it as long as you tighten them up all the time.
  16. squirrel
    you don't have to worry about it unless you have some oddball wheels.
  17. Moparhead
    Moparhead
    I'm figurin' painted steelies.I'll see what I can find Saturday.I ordered a set of mini trim rings from Jimmy,and I've got a set of spiders.
