Wheel cylinder keeps going out...
Discussion in 'The Hokey Ass Message Board' started by Jobe, Apr 24, 2009.
  1. Jobe
    Jobe
    from Austin, Tx
    Since I've had my Caddy (5 years) I have had to rebuild the right rear wheel cylinder twice, then replaced it with a new unit and I might have had to rebuilt it allready, can't remember. Just this one...why?
    All four brakes bleed just fine, have replaced hoses, shoes, etc...over the years.
    Any thoughts?
    Thanks
  2. 32SEDAN
    32SEDAN
    Check the shoe pivot points / pins to ensure there is not a bind. Pins could be bent...
    Ensure the plunger moves freely within the cylinder. Sometimes the rubber cups bind on the cylinder wall.
    Just some thoughts...
  3. fridaynitedrags
    fridaynitedrags
    What is it you find wrong with it when you remove it? Is it rusted from water in the line or are the cups worn out or what? Like 32SEDAN, I think there's something else goin' on.
  4. Jobe
    Jobe
    from Austin, Tx
    It is always leaking at the cups. I've cleaned out the line. I'll do a check of all the pivots, springs etc...but everything seemed fine. Thanks.
  5. squirrel
    The original one was rusty/pitted pretty badly, and the replacement was made wrong.
    Or maybe it's cursed.
  6. PONY
    PONY
    Have you checked the drum diameter? If it's past the Max O.D. the cups could be working towards the ends of the wheel cylinders causing leaks. You should be able to tell by how far out the star wheel adjuster has traveled.
  7. Jobe
    Jobe
    from Austin, Tx
    That's a thought Pony...thanks...and Squirrel...it's definately cursed!
  8. Deuce Daddy Don
    Deuce Daddy Don
    Remove wheel cylinder, peel back one end , look for any rusty residue, completely remove rubber, rod, piston, spring & check cyl. walls for ANY pitting.
    Then do same to other end.
    ANY PITTING FOUND--------REPLACE CYLINDER!!---------------Don
