wheel cylinder rebuild
Discussion in 'The Hokey Ass Message Board' started by DirtyJohnDeereHat, Apr 16, 2013.
  1. DirtyJohnDeereHat
    DirtyJohnDeereHat
    I have a 1950 chevy coupe with a leaky wheel cylinder. I pulled both fronts apart tonight hoping to just rebuild them with new seals. they both look like they have some flaking going on in there. can I hone that out or is a hone just for minor scratches?
  2. WillyNilly
    WillyNilly
    from NorCal
  3. DirtyJohnDeereHat
    DirtyJohnDeereHat
  4. 1971BB427
    1971BB427
    from Oregon
  5. SLCK64
    SLCK64
    $8 per kit from NAPA for the rebuild kit.
  6. Rusty O'Toole
    Rusty O'Toole
    Honing is only for cleaning up. If there is any pitting, replace them. If the pitting is minor you can clean them up and put in kits but they are so cheap these days it's not worth the bother.
  7. stampp
    stampp
    from Minnesota
    I would just replace them. Boring and resleeving will probably run you about $70-80 plus you then have to buy the repair kits. Having done 3 vehicles, I found that is is not worth it to resleeve the wheel cylinders since they last for a while and new ones are pretty cheap. I do recommend resleeving the master if you haven't done that. The stainless sleeve will make it last forever and it is about the same price to do a master as buying a new one without the stainless.
