Wheel cylinders
Discussion in 'The Hokey Ass Message Board' started by rottenikken, Feb 6, 2008.
  1. rottenikken
    rottenikken
    I have a set of four Wagner Lockheed wheel cylinders marked wf FD 18180 and wm FD 18179.I've searched all the reference books that I have to no avail.What is the application of these cylinders.
  2. wagner has a site online try that.
  3. rottenikken
    rottenikken
    Thanks...I tried it and no luck.These cyl have one mount bolt and is used in pairs per wheel ala early Chrysler.....
  4. sutliff fire
    sutliff fire
    I like a challenge so I checked my books (no listing) and had the same answer at the Raybestos and Wagner tech lines. Wagner gave me the name of an obsolete parts distributer: Tops 800-253-0725 in Pittsburgh. Tops had no luck either. If you have any more info on these cylinders, I can try to run with that.
    Good luck
    Kevin
  5. FD 18179/80, are 1 1/8" Wheel Cylinders, and fit Dodge Trk. Front, 56, 59-65. Ford Trk. Front, 51-60. GMC Front, 58-59. IHC Front, 54-56. and Stude Trk. Front, 54-64.
    HemiDeuce.
