Art & Inspiration Wheel Id
Discussion in 'The Hokey Ass Message Board' started by v-v, Mar 25, 2014.
  1. v-v
    v-v
    from Finland
    need to id these wheel. both are 5x5 bolt and 16". Like the look of right one
  2. 31Dodger
    31Dodger
    Looks like 1939 to 1941 Chrysler product on the right to me.
  3. bgaro
    bgaro
    this makes sense. i believe the later 40's where 5 on 4.5.
  4. v-v
    v-v
    from Finland
    How about that left one
  5. alchemy
    alchemy
    Black one is 40 to 48 Ford depending on the width. Rust one looks like it would fit a 28 to 35 Ford with the raised nibs inside the studs. But the wheel looks like a 40ish Lincoln with those hubcap clips on there.
  6. v-v
    v-v
    from Finland
    tires on rims are 6.50 if it would help
  7. bobsranchero
    bobsranchero
    this may help or not .the one on the right probably is not 39 chrysler i have two , there should be a hole between the lug holes for aline up stud on brake drum.
  8. Hnstray
    Hnstray
    from Quincy, IL
    The wheel on the right is probably a Lincoln wheel....'39/'40 era. They had the clips as shown.
  9. Ford bolt pattern is 5 on 5.5, Merc was 5 on 5 starting in '52.
  10. v-v
    v-v
    from Finland
    I mess up with that bolt pattern:confused: they are 5x5.5
