Wheel on Willys
Discussion in 'The Hokey Ass Message Board' started by hotrod--willys, Oct 2, 2012.
  1. hotrod--willys
    hotrod--willys
    Ok guys, can some one tell me the make of this wheel.:confused:
    They have ford bolt pattern
  2. bobwop
    bobwop
    from Arley, AL
    mid-80's spare of some kind.
    Olds Toronado?
  3. Ya I think yer right...not vintage just old?
  4. bobwop
    bobwop
    from Arley, AL
    hmmm, Ford pattern?
    Lincoln spare?
  5. 296 V8
    296 V8
    from Nor~Cal
    I think ....... stock Willys (hole sawed)
  6. bobwop
    bobwop
    from Arley, AL
    should be four bolt?
  7. Willy301
    Willy301
    My Willys truck was 5 lug, but the factory spare was a long lost memory by the time I got the truck.
  8. henry29
    henry29
    Is that a big valve stem for a tube tire?
    could be an old jeep wheel.
  9. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    They look like willy's wheels that some one has use a hole saw on the center. Do you want to sell them?
    Jimmy
  10. hemipwd41willys
    hemipwd41willys
    from Wyoming
    I would agree with Wheelkid. If you look at the center of the wheel where the lug holes are you can see the flats where the hub cap clips should be.
  11. I believe Mike Marinoff had front wheels like that on the front of his Willys G***er. Google images for his car.
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I believe Ollie Olsen had them also, I believe they're stock Willys of some sort?
  13. 296 V8
    296 V8
    from Nor~Cal
    Like I said
  14. hotrod--willys
    hotrod--willys
    Could these be the same wheels. Mike Marinoff.:confused:
  15. curbspeed
    curbspeed
    They are a stock Willys rim. They are a 4x16 and a 4.5x5 bolt pattern. I've had them before. They were used on a lot of the early coupes for racing because they were narrow. Some were even chromed like the ones in the above picture by the builders. They were made by Kelsey-Hayes. The ones I've had were stamped K-H on the back just like some Ford rims.
  16. hotrod--willys
    hotrod--willys
    Good information on the wheels. That puts this post to bed. Thank you curbspeed.
  17. Those are the ones I was thinking about, and yes Ollie Olsen had some too.
  18. hotrod--willys
    hotrod--willys
    I have looked at as many Willys to fined these wheels. I can not fined a single photo of a early Willys with these wheels. I see that some of the early g***ers used them. What the hell are they??? Come on guys I need your input. I'm ready to rechrome them for an extra set of g***er wheels for this project.
  19. xracer40
    xracer40
    Ollie Olsen's wheels.
