i'm looking for some 5 x 5 1/2 x 15 5" wide....for an a model. is this possable? i have a new set of 670 wide whites but no wheels.
Very possible. 57 thru I believe 64 Ford pick ups ( 1/2 ton only) used this size and they had the same center section as used on 40 thru 48 Ford cars. I bought 2 very reasonably from HAMBer Enjenho and 2 others from a wrecking yard, 1 off a 58 PU and the other off a 64. You can also get new repops from Wheel Vintiuqes in nearly any width but with freight they are be $150 +/-. Ted H
Wires??? If not Mopar wheels are that bolt pattern, 5 inchers started in about 55/56. Wheel vintiques makes a number of different wheels in those sizes and you can specify back spacing. I got some dual bolt pattern (GM/ Ford Mopar) smoothees in that size. Got them unpainted through Summit Racing for about 39 bucks. visit their webside at; http:// www.wheelvintiques.com
