Hot Rods wheel question and drum question?
Discussion in 'The Hokey Ass Message Board' started by hot rust, Sep 20, 2024.
  1. hot rust
    hot rust
    has anyone ever seen a aftermarket wheel ie: cragars. torque thrusts or 5 window mags in a 14 inch with a 5x5.5 bolt pattern? and i am using 45 fin buick drums on my project will a 14 inch wheel fit with these? thanks in advance hot rust
  2. Budget36
    Budget36
    Can’t see why not, but only concern would be the offset of the wheel, to make sure it doesn’t contact the drums.
    Also the drum diameter. If the wheel needs to “tuck over the drum” you’d need to get the tape on things.
  3. RICH B
    RICH B
    Don't know about specific wheels; but here's a picture of a Buick drum in a 14" wheel. The fins needed to be cut down quite a bit to fit inside the wheel. To me, the visible fins being trimmed detracts from the look of the drums; but I think it was described as a problem with a good transition from the cut fins inside the wheel to the full fins outside the wheel.
    Just Gary likes this.
  4. F-ONE
    F-ONE
    from Alabama
    I don’t really understand the affinity for 14” wheels in this case.
    5x5.5 in 14 is a rare bird in my opinion. By the time Ford went to 14s in the 1950s they were using the 5x4.5 pattern.
    I just think you’ll have better luck with 15s in the “Model A Pre-49 car and Ford Truck wheel pattern. Yes I know some Mopars and others used the pattern.
    Buick Drums..... do Cragars really go with those? I’m not nit picking but I’m trying to visualize that in my head.
    Just Gary, swade41 and The Chevy Pope like this.
  5. jimmy six
    jimmy six
    Not to complain about using Buick drums but looking at the photo and where the axle pin is supposed to intersect the ground at the center is so far off that it scares me. Last week at the outriders picnic there was one that was almost perfect using 15” wheels and a pretty deep rear offset on the wheel. Quite afew of us noticed it!
  6. hot rust
    hot rust
    wasn't going to go with cragars as i agree dont think they would fit the era, more into slotted mags for this build. i was just wandering if they were ever produced
  7. Budget36
    Budget36
    Are you asking if 14inch slots of cragars were produced to fit Buick finned drums?
  8. hot rust
    hot rust
    no just wandering if there were any produced as i have never saw any with a 5 1/2 bolt circle. i am looking for the 5 slotted mags for my build in aluminum
  9. F-ONE
    F-ONE
    from Alabama
    You should be able to find 15” slots in 5x5.5.
    14s probably not.
    I think 15s are what you want.
    Just Gary and Budget36 like this.
  10. dwollam
    dwollam
    Yes they made 14" 5 on 5.5 aluminum slot mags. I have 6 of them. I run a pair from time to time on my '40 Ford. With '40 front drums I had to trim the squarish edge on the inside of the wheel to clear the '40 drum. Now running F100 drums so no problem. Guess I could try them on my '32 with Buick finned drums when I get home in a couple weeks.
    Dave
  11. hot rust
    hot rust
    great dave thanks a lot i wasn't sure if they were ever produced.....interested in selling a pair of them?
  12. dwollam
    dwollam
    I might. I'll get back to you after our Model T trip is over in a couple weeks.
    Dave
  13. swade41
    swade41
    from Buffalo,NY
    Why are you set on 14's ???
    There's so many more tire choices in 15's as compared to 14's, in 15 inch aluminum slots the big center bore hole is more common than the small bore hole, so keep an eye on that.
    Big bore hole 5 x 5.5 for reference
  14. hot rust
    hot rust
    interested in selling a pair?
  15. enjenjo
    enjenjo
    from swanton oh
    I had a pair of 14 by 6 Torque Thrusts with a 5 1/2" bolt pattern back in the 70s on the front of my truck.
    58 Chrysler Imperial has 14 by 6.5 steel wheels with a 5 1/2" pattern too.
  16. dwollam
    dwollam
