wheel repair
Discussion in 'The Hokey Ass Message Board' started by lubber, Nov 24, 2009.
  1. lubber
    lubber
    from so. calif.
    I've just welded up a rusted out valve stem hole on a kelse hayes wire wheel, and know I need to find out what diameter to drill the new valve stem hole? Can anyone help?
    thanks,Scott
  2. 48flyer
    48flyer
    If it were me, I'd drill it the same size as the other 3 wheels:D
  3. lubber
    lubber
    from so. calif.
    You would be ***uming 48 that there are 3 others. And there in lies the rub, its the only one I have.
  4. 5window
    5window
    Ah, but it you are using a standard valve stem, then a lot of other wheels will have the same size hole.
    Scroll down for valve stem info here:
    http://www.heeters.com/tires.shtml
  5. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
  6. lubber
    lubber
    from so. calif.
    Thanks wheelkid.
