Technical Wheel Replacement
Discussion in 'Traditional Hot Rods' started by 42flattman, Jul 23, 2020.
  1. 42flattman
    42flattman
    Looking for a little info.....'42 Sedan....going to put Wheel Vintiques 14 series Gennie 15" wheels and tires on........on the fronts I know of a '47 that has 15x5 w/3" backspacing and 205/75R15 tires....I would like to do the same tires on 15x6 w/3.75" backspacing.....has anyone by any chance done this ?....I can't think that 1" wider is going to be an issue but thought I might check with the more experienced gentlemen out here before I pull the trigger on the purchase.
    Thanks for your input !
  2. Jalopy Joker
    Jalopy Joker
  3. fastcar1953
    fastcar1953
    They will be fine. They are a little two wide for the 5 inch wheel
