Wheel/Tire Questions
Discussion in 'The Hokey Ass Message Board' started by Mike Paul, Apr 26, 2004.
  1. Mike Paul
    Mike Paul
    I recieved a couple PM's to my want add and I thank you, but I have a couple of things I need to find out about that are stumping me. My front tires that I have for my A sedan are 670-15 with a 4.5" tread width. Should I run a 4 or 5" wide rim with this tire?
    Next question. In the rear I would like to have either 820 or 890-15's and they have a 5" tread width. What width rim should this tire be run on 5 or6"?
    The car will not have any fenders,so the only problem I might have is that the rearend is not really wide enough. With a 6" rim(46 ford) that has a 4" back spacing the tire rubs the side of the body.
    Thanks for the help....Mike
  2. yorgatron
    yorgatron
    i don't have any tires that skinny,so i don't know [​IMG] BTTT in case somebody else does...
  3. DrJ
    DrJ
    I've always heard to run the same width rim as the tread width and vice-versa.
    Or at least close.
    4.5" tread on a 4.5" rim etc.
    That way the sidewall gets the nicest looking bulge and works the best too
    With a 8.90 you probably want a 6" but a 8.00 or 8.20 a 5" would probably do.
    If the rim/tire hits the body reverse the rim on the center.
  4. jdubbya
    jdubbya
    I put my 5.90 fronts on a 5" rim, and my 8.20 rears on a 6" rim. They ride great, and look perfect. Just my 2 cents. -Joe
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Sorry, I can't concentrate on anything you wrote...
    Its something about a woman rubbing her boobs doing that to me.
  6. i'll second that
