Technical Wheel well to tire clearance
Discussion in 'The Hokey Ass Message Board' started by deucepickup32, Apr 30, 2024.
  1. Looking for an acceptable clearance dimension for tire to wheel well. My 32 Vicky had 1 1/4” spacers which I question being there. Have about 3/4” on one side and slightly more on the other with them removed. I know what to do to split the difference but am wondering what is optimal. Tires are Excelsior radials.
  2. squirrel
    Does it rub without the spacers? That's kind of the determining factor....
  3. We built em with about 1/4 of clearance
    deucepickup32 likes this.
  4. Not in a position to drive it yet as it’s in the process of steering installation
  5. Excellent and thanks.
    anthony myrick likes this.
  6. squirrel
    and some cars rub with 3/4" clearance. You kinda need to go for a drive before you can be sure!
    also some guys don't mind if it rubs, others do.
  7. DDDenny
    Kind of depends on if you are using an anti-rub bar.
    sdluck likes this.
  8. Anti rub bar ?
    theHIGHLANDER likes this.
  9. theHIGHLANDER
    theHIGHLANDER
    I know, right? Sounds like a men's specialty soap...:eek:
  10. DDDenny
    Some call them sway bars, but they really are anti-sway bars.
  11. Panhard bar
  12. DDDenny
    Completely different systems.
    Panhard on my roadster
    Anti-sway bar
  13. The car has a transverse spring as well so probably don’t need either
