WHEELS FOR 1965 BUICK WILDCAT
Discussion in 'Questions & Suggestions' started by michaela, Apr 15, 2004.
  1. michaela
    michaela
    DOES ANYONE KNOW WITCH CARS CAN BE INTERCHANGE WITH THE WHEELS FOR A 1965 BUICK WILDCAT? I NEED A SET OF WHEELS FOR MY CAR.
  2. sacto_wildcat
    sacto_wildcat
    you can use the wheels off of a third generation camaro if you buy the bolt pattern adapters. i did this on my 4 door wildcat and it pushed the wheels out of the wheel well a little but not to bad. hope this helps...
    ps. there is a guy parting out a camaro on ebay, and he might still have the wheels if you're lucky, otherwise try the junk yard
  3. Satinblack
    Satinblack
    I dont quite understand what your asking? [​IMG] If you want to know what other types of wheels will fit your car, then any car with 5 on 5 inch pattern will work. If your asking what other cars use the same wheel as a 65 wildcat then most large buicks from 65 up with the rally wheel. The 64 and older looks the same but the center hole is smaller so your caps wont fit
  4. sacto_wildcat
    sacto_wildcat
    attn: satinblack
    do you know if 20" wire wheels will fit on a 65 wildcat?
  5. michaela
    michaela
    SACTO WILDCAT WIRE WHEELS ARE YOU A*******?
  6. Satinblack
    Satinblack
  7. manyolcars
    manyolcars
    [ QUOTE ]
    [/ QUOTE ]
  8. manyolcars
    manyolcars
    [ QUOTE ]
    attn: satinblack
    [/ QUOTE ]
