i don't know alot about suspension stuff so i need to know..if i can put mustand II rotors on a traditional styled drop axle front end(i know disc brake are not traditional)i want to change out the IFS front end to a cleaner looking axle set up,but i really like my wheels and they are 4 lug,,,thanks alot,george
Just putting the rotors on is only half the battle... Would anybody make a kit to mount calipers on early spindles to make those tiny disk brakes work?
thanks for the input...hadn't planned on changing it but bought a frontend for a price i couldn't pass up...it has drum brakes...could the lug pattern on those be changed?
some of makers of the the kits out there for a disc conversion say they can drill the rotors with any bolt pattern. If you have 13 or 14 inch wheels you may have a clearence problem. Give them a call.
