Technical Wheels that will fit
Discussion in 'The Hokey Ass Message Board' started by daniel gallocker, Dec 19, 2021.
  1. daniel gallocker
    daniel gallocker
    Good morning guys
    so I finally got my disc brake conversion kit for my customline. I need to up the size of the wheels. Currently there are 15 inch wheels on the back and 14 on the front. I believe the 15s would clear the kit in front but clearance issues in bsck would arise I’m sure as it’s already close. I know have a 5x4.5 bolt pattern but I’m wondering if I can use any wheels with that bolt pattern or do I need to worry about center bore? Should I just stick with other Ford wheels? Or stick with just cars. I have seen other wheels in that bolt pattern for lexus and hyundai but I wasn’t sure if they would fit.
    Any advice greatly appreciated
    daniel
  2. 5window
    5window
    Can we ***ume this is the '55 in your profile? Pictures,especially of clearance issues might be useful
    hotrodjack33 and lothiandon1940 like this.
  3. squirrel
    There is such a thing as a "disk brake wheel". It has a different center and rim design, to allow room for the caliper.
    We can guess all day long what wheels you have, or what style wheels you want, but without more specifics, it's really hard to make recommendations.
    Make sure the wheels you get are designed to work with disk brakes. Most wheels made since the 1970s are. Older wheels, like original 55 Ford wheels, are not.
    Also pay attention to center hole diameter (it has to be as big or bigger than the center part of the hub or axle), and also to wheel back spacing. Wheels off front wheel drive cars generally have way too much offset (and back spacing) to work on older rear wheel drive cars.
    hotrodjack33 and 210superair like this.
  4. hotrodjack33
    hotrodjack33
  5. miker98038
    miker98038
    It’s hard to know what combo you’ve got. 55-56 Ford’s and birds used 15 in rims. 57 birds and I think Ford’s went to 14”. The front spindles, etc are the same 55-56 ford, and 55-57 bird. Many 55-56 disc conversions use a granada front hub/disc, turned down to fit in the early ford wheel center. But you don’t say what you’ve got.
    Some conversions use a spacer that move the fronts out about 1/8”. That will affect clearance on some wheel/tire/offset combos.
    Post it all up, there’s probably a couple ways out.
    daniel gallocker likes this.
  6. lake_harley
    lake_harley
    I used a Speedway disc brake kit with 5 X 4.5" pattern on the front of my Model A using '37-'41 Ford spindles. I believe it's some sort of GM rotor and used "Metric" GM calipers. Wanting to use 5" wide wheels on the front and 7" on the rear I had a friend give me a pair of 15 X 5" wheels that I believe were of Ford origin, but the center hole was too small to fit over the disc brake rotor in the front. I have no idea what the wheels came off of, but thought I'd mention it so you're aware that all stock steel wheels may not work out. Just a guess, but I'd say the hole in the wheel was about 1/8" too small to fit the rotor.
    Lynn
  7. evintho
    evintho
    Clearance is tight in the back for '52-'59's. However, there's a guy in the social forums that's running 18 x 10 American Torq Thrusts on this '54 with stock rearend. He's got 5.74" of backspace. That gives you an idea of what's possible. If you want to go with steel wheels, how about custom made wheels through places like http://thewheelsmith.net/ or https://www.wheelvintiques.com/wheels/fwd.html
    They can make any size you want with any size backspace and width. Their prices are surprisingly reasonable.
  8. miker98038
    miker98038
    Wheelsmith made me a set of 15x7 for the back of the bird, 4” backspace. I ran 10” cheaters on those.
    But you need to know the center hole and possible change in offset for the front. And the type/size/brackets on the front calipers. Otherwise, it’s a shot in the dark on a modified car.
    Carefully measuring, I’ve got 15x7’s and 225/60’ and 235/60’s on the back of a stock 55 bird. But there is little room for error in the wheel specs.
  9. daniel gallocker
    daniel gallocker
  10. daniel gallocker
    daniel gallocker
    That’s what I have to figure out I believe. That’s where I need to know which ones will fit as is for now.
  11. daniel gallocker
    daniel gallocker
    So the disc brake kit I got is the willwood one which has some adapter to make it fit onto my spindles so I don’t need to change them out. I need to have at least 15 inch wheels to clear the disc brakes according to the kit. So I’m looking to get some basic Steelies or something just to clear and ride on them for now. I’m not ready to pick my final wheel set up like spending big on the wheels and tires. I’m thinking of going to 16s all around for now and I guess I need to figure out what 16 inch 5x4.5 bolt pattern will work. There’s a chart a fella posted above that will give me the stats I think I need to make a decision
  12. daniel gallocker
    daniel gallocker
    Thank you will check that out
  13. hotrodjack33
    hotrodjack33
    If you are considering 16" rims, I used a set of 1940 Dodge 16' rims on my Sedan Delivery which had 4 wheel disc brakes. The 30's-40's Mopar rims use the 4.5 bolt pattern and have a large enough center bore. They bolted on with no issues.
    dana barlow and daniel gallocker like this.
  14. miker98038
    miker98038
    I think jimmy six has the Wilwood kit on the front of his 56. Might be able to help. Typically (I don’t know about Wilwood), the spacers used to retain the spindles are what move the front wheel out 1/8” or so. That’s the set up on my bird.
    Given the limits for tire height on a 55, I’m kind of getting a bad vision about what tires you have to put on a 16” rim.
  15. daniel gallocker
    daniel gallocker
    Yes there are some spacers that came in that kit.
    I’ll have to message jimmy.
    Yeah I hear that on the tires. I’m not trying to go low profile or anything. I’m gonna have to jack the car up and see what kind of room I’m playing with.
  16. miker98038
    miker98038
    Watch the turning radius (or however you say that) on the front wheels. Real easy to hit something before you get to full lock.
  17. daniel gallocker
    daniel gallocker
    According to that website center bore is 70.3
    looks like tons of other Ford wheels will work and some Acura and Lexus
  18. daniel gallocker
    daniel gallocker
    Thanks for the tip. Gonna have to jack her up again and measure that !!! Lol
