Hot Rods Wheelsmith Wheels
Discussion in 'The Hokey Ass Message Board' started by butch27, Feb 6, 2010.
  1. butch27
    butch27
    I have a pair of Wheelsmith rims on my '47 Ford rear end. They are the Darn universal fit pattern. I need to know WHAT baby moon hub cap will fit since they only have INSIDE nubs AND the old banjo axles stick out a bit too much for reg moons.?
  2. Acme Speed Shop
    Acme Speed Shop
    MODERATOR
    from so cal
    You have to use the caps that Wheelsmith sells. I've had their wheels on a bunch of cars and nothing fits but the ones they sell.
  3. chris sage
    chris sage
    from CA
    You can run a ford cap on those wheels 47 ford that would clear the hub on you car.if you want a beby moon look you can get a 1940 ford plain cap that looks great also
  4. butch27
    butch27
    Thanks: I'll check it out.
  5. butch27
    butch27
    Will they clear the end of the axle and what about the inside diameter where the nubs are on Wheelsmiths?
  6. chris sage
    chris sage
    from CA
    Yes they are the same caps.Its just the back that is different
