Figure its time I contribute something to the HAMB, other than questions about my transmission . OK, so the wheelwells on my 55 Plymouth were cut out some time in the past, by a previous owner for its drag-strip days. Apparently it had some big honkin slicks on it, or something. Any case, they hacked the wheelwells with what appears to have been a chainsaw and an axe. Heres my somewhat ghetto-rific way of correcting this. Not only am I tired of seeing them, but the car is going on eBay in a couple days figure it not looking like it was attacked by metal-eating rabid beavers would be a strong selling point. Step one: Take welding wire (or a coat hanger), and bend to the desired shape. I somewhat followed the stock lines. I use the term followed very loosely.
Step two: Used masking paper (or butcher paper anything, really), to get a pattern from the wire-form and wheelwell. Note: An exacto-knife would be a lot easier than a rusty steak knife, which was my method (keeping with the ghetto-rific theme)
Step three: Transfer the pattern to a piece of plywood. This will serve to be the ghetto-buck on which the arch will be formed.
Step five: Using a suitable, and stable work surface, clamp the ghetto-buck down. The tailgate of a 60 Chevy truck works splendidly, by the way. For the lip part of the wheelwell, I used 5/8 thin wall tube. It was what was lying around, and just happened to be the perfect size/shape for this. Place one end of the tube, so that it is held securely by the clamp, and bend it around the ghetto-buck. Bends MUCH easier than youd think and with the relatively gentle radius of the bend, there is little chance of the tube kinking. Just go slowly.
Step 7: Cut the ends. I get a lot of questions about this saw its a depression-era Supercraft dual arm radial mount (cuts compound angles), with a 40s Porter Cable saw. Love this thing.
Steps 8-11: After cutting the tube, I transferred the pattern to some 16ga sheet metal that was lying around. To keep with the full-on ghetto theme, the metal came from a 70s Monte Carlo door. A couple minutes with some tin-snips and some forearm pain Welded the sheet metal to the tube, going slowly to avoid warping. (forgot to take pics of that). Ground the weld, hammered any imperfections out
Step 12: Put a flange on the piece, so that it sits behind the fender, and flush at the face of it. Not having any other method of forming a flange, two pieces of s****, tacked together, and more hammering fun Hammer young man, hammer
On the car: The fill piece is actually perfect the poor hacked quarter panels yet more hammering. Sorry for the odd angle of the pics on the car theres a tree in the way. Cant get the car into the shop area, as the 60 Chebby truck is in the way so did all this in the yard. Tomorrow Ill make the drivers side, weld both onto the car, do lots of hammering and cursing of the previous owner, more hammering, more cursing, and hopfully itll be finished. Ill post a couple more progress pics, and the completed pics then So far, it took about an hour, with minimal tools other than a MIG welder, nothing cost more than a few bucks.
Looks good. I've got to do the same thing to my '55 Plymouth on account of that whole area being fibergl***. -Jeff
