Customs When did Ford start using sealed beam headlamps?
Discussion in 'The Hokey Ass Message Board' started by 65standard, Jun 3, 2014.
  1. 65standard
    65standard
    I have a 1938 Ford Cabover truck with original 6-volt headlamps and amber turn signal inside the light buckets. The gl*** lens is separate from the reflector. I found a better set of headlight buckets and stands from a 1938 Ford pickup, but these have regular sealed beam headlamp in them with no provision for the turn signal.
    Is this a factory option or were they converted to sealed beam? I want to keep the non sealed beam lights because I like the bug eye look better and I want the turn signal in the reflectors.
    Anyone know when a Ford started using these sealed beam bulbs?
  2. 31 B'ville
    31 B'ville
    from SE Pa
    I think all US manufacturers went to sealed beams in 1940.
  3. DICK SPADARO
    DICK SPADARO
    Headlites that look similar to 38/9 PU with seal beam bulb are most likely 1940-41 big truck units, they use a seal beam bulb rather than a reflector. My question to the people that install turn signals in the headlite has been when did you see a DOT headlite with a turn signal unshielded as a unit. To me it would be hard to look at a headlite at night and determine that the flicker was actually a turn signal. Yes I know that you can get away with this but the question is to the safety of the unit when the actual headlight is burning not just being used as a stand alone turn signal.
  4. Rusty O'Toole
    Rusty O'Toole
    Sealed beams were introduced in 1940 and quickly became mandatory. Bulb type headlights were made illegal except for pre 1940 cars. So every car maker switched to sealed beams in 1940 or 1941 at the latest.
  5. HOTRODPRIMER
    HOTRODPRIMER
    As I recall they were designed in 39 but became mandatory in
  6. tb33anda3rd
    tb33anda3rd
    i did not realize bulbs were made illegal.
    don't new cars use bulbs?
  7. 65standard
    65standard
    My original 1938 headlamp reflectors have an amber bulb just below the headlight bulb as an unshielded unit. I'm just guessing that the amber bulb is the turn signal. Truck has factory turn signals, but maybe those front amber bulbs are not front turn signals? I don't really know.
  8. seb fontana
    seb fontana
    from ct
    Crosley had the pre 40' bulbs up to at least 47' and maybe through 48..When converted to sealed beam the parking light had to be installed as a separate unit..
  9. alchemy
    alchemy
    Pretty sure no cars had turn signals until the 50's. Those amber bulbs in your headlights are the parking lights (driving lights). They were the same as cowl lights in the early 30's.
  10. I know Buicks had turn signals prior to WWII. My 47 had 'em
  11. Turn signals were optional or add on on most cars before about 1954; more expensive makes got them standard before cheaper ones.
    Sealed beams came about in 1940 and then a lot of aftermarket kits could be had to convert older headlights to use them. Some went so far as to cast an alternate bezel for the late 30s cars with fancier lens setups. 37-38 Ford and 39 Plymouth a**** others.
  12. Rusty O'Toole
    Rusty O'Toole
    I know in the sixties some European cars with quartz halogen lights were illegal. They had to change them to sealed beams to sell in the US. Many expensive European cars of the sixties and seventies have different headlights in the US version.
    They did eventually change the law.
  13. jetnow1
    jetnow1
    from CT
    Buick introduced the turn signal in 1939. Of course the signal unit was located in the
    center of the trunk rather than outboard in the rear.
  14. 33sporttruck
    33sporttruck
