using stock 36 radius rods ... i have the radius rods - 36 i have a flatter 36 rear crossmember - going to switch it in are the springs the same? 2.5'' wide how do you do the rear tube shocks when I make the weld in tab do i make it so i lower the axle in a bit? do i reverse the spring now? do i fit the radius rods wider than stock use a wider bush at the front? anyone got anypics of a similar installation. thanks
