When is Billet cool?
Discussion in 'The Hokey Ass Message Board' started by metalshapes, May 30, 2006.
  1. metalshapes
    metalshapes
    Answer:
    Never.
    But I hope this will do the job for me...
    I am mating a couple of carbs off a Maserati/Citroen engine to a old Rochester Fuel Injection intake.
    I wasn't sure if I was going to Fab or Cast the adaptors, and then I found some chunks of Aluminum at the S****yard for $50.
    There is still a lot of work that has to be done,
    I still need to Repair the Intake, mount the Adaptors, mount the Carbs, finish cutting the ports ( and ports them ), build a linkage, synchronise and dial in the Carbs, etc...
    And I'll file off the sharp edges on the outside of the Adaptors to make them look a little better...:D
  2. t-town-track-t
    t-town-track-t
    from Tulsa
    sand blast them and they will look more like cast
  3. jub
    jub
    from York, Pa
    If you make it yourself. Like you did
  4. billet is cool for crankshafts. looks great...but do you want to admit you used SM parts in public...:D
  5. Django
    Django
    from Chicago
  6. SinisterCustom
    SinisterCustom
    Yeah sandblast 'em.
    Beautiful work BTW.
    Don't call ya metalshapes for nothing eh?
    Josh
  7. hemispherical
    hemispherical
    from indiana
    billet is best when its used to make big honkin connecting rods for top fuelers!!!
  8. stickylifter
    stickylifter
    from Detroit
    Yeah! It's cool when you make it yourself... usually. At least in your case. round off those razor sharp edges and sandblast 'em.
  9. rockabilly_bass
    rockabilly_bass
    billet is cool when you do it yourself , anything you do yourself and works is cool in my book
  10. touchdowntodd
    touchdowntodd
    those are nice, i would blast em to make em look right too..
    i was all ready to answer ... "when youre laughing at it"... but thats looks NICE
  11. desertdroog
    desertdroog
    Billet Aluminum makes great lowering blocks!
    Does this mean I cannot show my 54 Ford around here anymore? They were handmade!
  12. dabirdguy
    dabirdguy
  13. monsterflake
    monsterflake
    as Paris would say, ''That's hot...''
  14. elcornus
    elcornus
    BILLIT,
    OK,
    IF you carved it out your self on the mill and or lathe, which you did.
    NOT OK,
    If you cut it free from it's plastic wrapper.
    Just a machinist's opinion.
  15. metalshapes
    metalshapes
    Thanks guys... I feel a little better now...:D
    Honestly, I'm more concerned about their shape on the inside than what they look like on the outside.
    But I know I won't be able to leave them looking like that.:D
    The nice thing about these DCNF Webers ( off a SM like FB said ), is that the bores are real close together.
    So that gives a pretty straight shot down the SBC ports.
    They are a little on the small side ( only 42mm ), so this should work nicely as a Street setup.
    Hopefully this will give good Torque and Milage on my 327.
    I had to cheat a little with the placement of the Right Rear carb.
    Its pushed foreward 3/8" to clear the Dist.
    That will hurt the flow of the RR ( #6) intake port a bit, but hopefully it wont be so bad it will give me tuning problems...
  16. racer756
    racer756
    Billet is really only cool when it comes in the form of a New Engine Block and set of Hemi Heads from BAE.(Brad Anderson Enterprises) And only when they are installed in my Funny Car. Other than that,Keep it away from my Rod.
    www.donhudsonracing.com see its not so bad in this form....
  17. Mr Shapes,
    Billet is cool when you call it pig.
    I personally think there is a difference between aluminum mechanical parts and billety googawes to try and dress one up.
    M*** produced parts are or where most often cast, its the cheapest or was the cheapest way. One off parts on the otherhand were most often carved out of a chunk of whatever was the lightest and or the most available.
    I like the pieces myself you made myself and love the look of a fine machine finish.
    Ever get close up and personal with a pair of crietz modular raceing wheels? Late 50s or early '60s I believe was when they were made. Hard to tell of the centers are cast or carved.
  18. attitudor
    attitudor
    from Finland
    That is very impressive use for Webers. I have 4 of those carbs too waiting for better use.
  19. 50Fraud
    50Fraud
    Woooo. Billet or no, that's a good looking system.
  20. Merc63
    Merc63
    Doesn't that really work for ANY part on your car you bought instead of made from scratch?
    I dunno. I remember some cool billet stuff being made by L'il John for his own cars back in the early-mid '70s...
  21. 47bob
    47bob
    Thats GOOD billet, you made it. Be proud of it and don't disguise it. BAD billet is bought in a store shrink wrapped.
  22. flt-blk
    flt-blk
    from IL
    Nice work Alex.
    I like your integration of European products to make American stuff better.
    Now about that 928S drivetrain in a T roadster. ;)
  23. Round off edges
    dunk in muraitac acid bath ....
    then paint it then s****e off paint ....
    then add used axle grease and wipe off grease that is on outer areas....
    file/grind off an area that could hold a serial no.?
    then use it find out it does not work so good ???
    then sell on eway as Von Dutch made
    go on extended vacation...
  24. VonMoldy
    VonMoldy
    from UTARRGH!
    I think billet is cool when it doesnt look like the sterotype of billet ****. FYI Those webers are used alot in aircooled VW's looks like you have a few but incase you need more or parts might be easier to find em through VW sources than say searching for maserati carbs probably alot cheaper too! FYI
  25. metalshapes
    metalshapes
    A lot of the VW setups seem to use the 40mm version of this carb. ( to small...)
    I asked a couple of VW spe******ts here in town and they were less than helpfull.
    I seen a couple of sets on Ebay in the last year or so, but they went for a lot of money.
    And they came with Bug Manifolds and Linkages that I didn't need....
    The first 3 ( one complete set off a SM ) were cheap.
    Cause I wasn't looking for them...
    The 4th one cost me almost the same amount.
    I got it from a Citroen spe******t, and he was able to match it up to the same stamping #s as the three I already had...
    I just love the Intake Roar of an Engine on Webers.
    Can't wait to hear what my 327 will sound like.
    Should drive pretty nice too...:)
  26. chiefbobber
    chiefbobber
    from NH
    So that's what that big machine in the other room is for............. Nice work!!!
  27. scottybaccus
    scottybaccus
    Billet IS Cool.....
    Until it's polished...:eek:
  28. ynottayblock
    ynottayblock
    those are bad-*** dude. i love seeing handmade parts.
  29. theHIGHLANDER
    theHIGHLANDER
    My vote too. I don't consider that to be billet. I consider that as resourceful. Very nice work and well thought.
