When is Billet cool?
Discussion in 'The Hokey Ass Message Board' started by metalshapes, May 30, 2006.
  1. cool57
    cool57
    When it's functional, not billet for the sake of billet. (did I say that right?:confused:)
  2. Gemini EFI
    Gemini EFI
    The flow difference will be nearly imperceptable.
    If you have a wild cam,intake pulses may require balance tubes, to ease tuning.
    Gemini EFI
  3. robber grin
    robber grin
    I dunno... but that is nice work and looks cool as hell mocked up too.
    rg
  4. jakespeed63
    jakespeed63
    I have to concour with most everything that was said, especially the mixing of european and American componants. Our forfathers did this exact thing when they came back from WWII. Ever hear of a Allard J2 or AC Ace.
    Congrats on the nice workmanship and the engineering concept.:cool:
    ...when was billet cool? when Lil' John Buterra carved out parts for his killer Hot-Rods, starting back in the early 70's.:cool: Still cool if you did it yourself!
    JT
    P.S. Aluminum weighs less, makes your car go faster, carbon fiber weighs even less, makes you win races, like we did at 24hrs of LeMans 3 years ago.
  5. metalshapes
    metalshapes
    I've done some more work to it...
    Welded some dividers back in, welded a piece of Aluminum in on one side of the port to tighten the curve of the Port.
    Matched the Ports to a Double Hump Head, cut the ports in one of the Adaptors, and matched it to the Manifold.
    ( needs a little more cleanup, but the basic shape is there.)
    2 down, 6 to go...
  6. Fossil
    Fossil
    Was all of your milling work done on a manual Bridgeport?
    -Scott
  7. MyOldBuick
    MyOldBuick
    Very cool. I'd love to have the tools/talent to do crazy stuff like that. Form following function without the "mine is bigger than yours" (referring to credit card debit . . . pervs).
  8. metalshapes
    metalshapes
    Yeah...:)
  9. Nick79
    Nick79
    from Austin, TX
    Was thinking the same thing. What's the difference between using a chrome pulley and a billet pulley if you didn't make either? You're still buying something that is m*** produced by a 3rd party.
    Billet for the sake of Billet looks tacky in my mind as well. Creativity and ingenuity is usually cool to me....regardless of the material.
    My $0.0000000000001 as a FNG
  10. metalshapes
    metalshapes
    Thanks guys.
    I thought I had already posted a pic of how I cut the holes in the Top Flange of the Adaptors, but I didn't.
    So here it is...
  11. Aman
    Aman
    from Texas
    It's only cool if you make it with a hammer and chisel Fred Flintstone sytle. CNC machines are for gold chainers!:D
  12. Zumo
    Zumo
    Second that. And when it is used approprietly
  13. fab32
    fab32
    Just another example of what you can do with a Bridgeport (time and talent also figure in). I wouldn't trade mine for anything. Alex, were your trained or self taught on the maching stuff?
    that is one cool piece of billet and like someone said it harkens back to L'il John and the start of the billet craze. It just got out of hand when it started to be m*** produced. One off parts are where it's at and since it's going on your roadster that will make it even more cool.
    Frank
  14. Fossil
    Fossil
    Billet is just another type of material to work with, like castings, plate, bar stock, etc. It's what you do with it that makes the difference between cool/trick and "billet" as a derogatory term. Looking at the photos here...and knowing a LITTLE about what it takes to turn out something like this from plain stock...I have to say "outstanding work". I got my hands on a clapped out Bridgeport 2 years ago. Thought I'd teach myself how to use it and make some parts for the hot rod. I've been reasonably successful but not to this level. A LOT of thought, planning and math goes into something like this, along with many hours of making chips. Cool!
  15. Nekronomicon
    Nekronomicon
    Its fine if its something you made for sure, Tyson made this handbrake handle for me and I love it-
  16. metalshapes
    metalshapes
    I'm not a Machinist.
    I was able to buy the Mill some time ago, and I'm figuring it out as I go...
    When I did a modified Intake for my Turbo Experiment on a English Ford Engine ( It uses a Maserati Carb and Pressure Box on a Modified aftermarket intake ), I started to think this might be possible too.
    So I tried it...:)
  17. metalshapes
    metalshapes
    Some more progress...
    All the ports in the Adaptors are cut.
    2 of the Adaptors are rounded off and smoothed out on the outside.
    And I started to build the linkage...
  18. My old lady would love it, too!
  19. Blair
    Blair
    from xx
    It's funny to see this because I have an early rochester manifold with some cast adapters to three bolt flange carbs. I'm running it with 4 chrome 97's. It has had all of the numbers ground off because it was chromed. I'll post some pictures if you are interested.
  20. metalshapes
    metalshapes
    Yeah, I'd like to see that setup...
  21. flt-blk
    flt-blk
    from IL
    Looks like good progress.
    So are you becoming the European carb conversion to American V8 spe******t
    in Tuscon??
  22. metalshapes
    metalshapes
    Nah... I'm just having fun with it...:D
    And putting 4 Webers on a V8 is something I've wanted to do for a long time.
  23. Flexicoker
    Flexicoker
    that looks wicked ***y after all the smoothing. You have way more patience then most to pull of something like that.
  24. propwash
    propwash
    from Las Vegas
    I didn't see no BILLET parts...just some real machine work, by a real hotrodder
    dj
  25. Flatdog
    Flatdog
    It ain't billit if you make it yourself HOTRODDER.
  26. Blair
    Blair
    from xx
    Here are a couple of pics. The adapters are cast aluminum which were then chromed. The carbs aren't ***embled, I need to finish rebuilding them. I have some "horseshoe" linkage which I don't think I am going to use. I really don't know how I am going to do the linkage yet.
  27. JamesG
    JamesG
  28. I just checked and it looks like I was thinking incorrectly, but there's a mob over here that make 4-carb Weber manifolds to suit Holden and Windsor V8s, including linkages to suit or adaptors to allow fitment of the carbs to either of these motors' existing manifolds. I thought they might have done Chev too.
  29. metalshapes
    metalshapes
    I've seen Intakes for IDA's and IDF's on SBC's, 289/302 SBF's, IDA's on a 351C, and I believe a IDF ( or maybe it was a IDA )intake for a 351W.
    There is a DCNF ( those are the carbs I'm using ) Intake for the SBC, but the Carbs are all in line, Maserati Style.
    I wanted them sideways to line the bores up nicer with the Intake ports.
    After I started doing this, I got some P/M's warning me about the DCNF's when you run them like that.
    They flood real easy going through corners...
    I opened one up to see what's going on, and I think I've figured out how I need to modify the Carbs so that wont be as much of a problem.
  30. metalshapes
    metalshapes
    That looks cool...
    Thanks for posting those pics.
