Customs When Life Gives You Lemons!
Discussion in 'The Hokey Ass Message Board' started by Greaser Bob, Oct 1, 2014.
  1. Greaser Bob
    Greaser Bob
    Well I bought this motor as a 327, but after reading crank number it turns out to be a 283 instead-I **** again. But I was able to see the piston walls were fresh as are the valves-so that's a good thing. So I say screw it, I'm using it anyway!
    Thought I would post a picture of it before the engine swap happens next week-when the REAL work begins!
    volvobrynk likes this.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Nothing wrong with a 283,KENDEUCE has a wicked 283 in his vicky. HRP
    volvobrynk, Bubba1955 and Greaser Bob like this.
  3. joseph.peter.carter@us.ar
    from USA
    I would check the block casting number on the back of the block, as well as the ID number on the tab, right side. some people would install a 283 crank into a 327, back in the day.
  4. brett4christ
    brett4christ
    That engine ****S! You will NOT like it!
    Just put it in a wood box, ship it to NC to get it as far away from Cali as possible, and I'll be sure it gets a proper resting place! :)
    volvobrynk and Greaser Bob like this.
  5. bobss396
    bobss396
    Nothin' wrong with a 283, I've had loads of them that really cranked.
  6. Greaser Bob
    Greaser Bob
    Yah I know very little about 283's and how they run so I'm getting stoked to fire it up soon!
  7. khead47
    khead47
    Check the bore size. You may have a 301 (sometimes referred to as a 302). A real rpm machine!
    40fordtudor and volvobrynk like this.
  8. The staggered bolt pattern Valve Covers make the heads early style (pre 59)
  9. Greaser Bob
    Greaser Bob
    I ran the numbers on the heads, they are earlier Corvette.
  10. Greaser Bob
    Greaser Bob
    I knew the valves needed to be adjusted, so today I removed the intake to see if the lifters were solid or hydraulic. They look solid to me-am I correct?
    I could also see through the spark plug holes the pistons were more of a dome top, and had 0.30 on all of them.
