Hot Rods When to Box Rails?
Discussion in 'The Hokey Ass Message Board' started by JeffreyJames, Sep 24, 2008.
  1. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I have been gathering as much information about building my '32 frame as possible but I still have a few questions for you fellas. When you are building a frame with or without a JIG, When is the appropriate time to box your rails? Would you box them before the Cross Members and X-members are in or would that be the last thing to do? Or would you box the rails after you "tie" the two rails together with the crossmembers? Would the heat tweak the rails before making it difficult for the crossmembers to be welded in correctly?
    My logic is that if this was done on a Original '32 frame, the Boxing plates would be the last thing to weld in because everything was already there. Any sense to this?
  2. dave lewis
    dave lewis
    from Nampa ID
    I prefer to box after installing crossmembers..
    My 3cs (inflation)
    Dave
  3. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    I like to box is after I put the front and rear cross members in so I can weld the cross members inside the frame.
    You wont warp or tweak the rails if you skip around when you're welding the boxing plates in. Tack them in every coupe of inches down the frame first, then go back and weld the length of beetween the tacks, alternating from side to side and back to front.
  4. I too install the front and rear cross member and X member before adding the boxing plates. HRP
  5. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I am seeing a trend.
    HOTRODPRIMER, do you weld the X member to the inside of the rails like the Front and Rear Cross Members? I had thought that they were welded to the Boxing plates but it would make sense now that you said it because there were no boxing plates originally huh? So I guess I would trim the boxing plates around the X member as I saw fit right?
  6. daddio211
    daddio211
    Don't forget to routinely measure as you weld to make sure nothing shifted! The slightest bump could shift 1/4" or more and won't be recognizable to the eye.
  7. pitman
    pitman
    First frame I modified, made the mistake of welding the top portion, then went back and welded the lower boxing plate joints...frame took on a lovely sweep, or damned curve upward, depending upon your point-of-view!
    So now I alternate side to side, front to back and above and below.
  8. rustyford40
    rustyford40
    from Mass Bay
    I run a pipe inside the boxing for wires.
  9. The Hop Walla
    The Hop Walla
    from Dallas
    Nice tip, rustyfor40.
  10. whats the difference between flush and steping the boxing plates? stronger, or cosmetic?
  11. This is a photo of the frame under my truck,,, HRP
  12. rustyford40
    rustyford40
    from Mass Bay
    the step is stronger
