Technical Where are you buying your flathead cam from?
Discussion in 'Traditional Hot Rods' started by 64Pony, Feb 4, 2021.
  1. 64Pony
    64Pony
    I’m looking to get a 1007b but my core is too worn for a regrind. Is reds the only one to buy new?
  2. Look in the parts for sale here and FordBarn.Also which flatty do you have?
  3. 64Pony
    64Pony
    59ab
  4. Ziggster
    Ziggster
    Too bad. In the last couple of years since I purchased my flathead and while looking for parts I don’t think I have ever seen just a cam for sale on our version here (kijiji) of Craigs List. Seen plenty of engines and cranks. I had Pete regrind mine to a 1007B. Good luck.
    warhorseracing likes this.
  5. Pete does great work.
    Did a regrind for my 8BA,,,,,looks awesome,,,,,good price as well,,,,quick turnaround .
    He’s here and on the Barn .
    He might even have some old cores to use for your engine,,,,,it would be worth a check .
    Tommy
  6. Atwater Mike
    Atwater Mike
    DELTA CAMS!!!! Tacoma, Wash. Lots of guys use Delta cams, so do I.
    They ground me a 406 solid cam from a raw new Ford casting;
    I also sent them an old Navarro cam, the main journals were worn too far to spray them...So, they went into their stock of new old stock flathead cams, and ground me a Winfield SU-1R. Adjustable tappets are also available, but I had a new set of Johnsons.
    Delta cams are (were) the favorites of Patrick's Speed Shop, also.
    kidcampbell71, rpm56 and akoutlaw like this.
  7. ronnieroadster
    ronnieroadster
    Pete can do it for you he should have some cam cores as well.
  8. Kiwi 4d
    Kiwi 4d
    Reds lists them for $385
    What other profiles does @KiWinUS have other than L100. Tony is a great guy to deal with.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Might give Delta Cams a call too.
  10. x77matt
    x77matt
  11. Jim Bouchard
    Jim Bouchard
  12. Fortunateson
    Fortunateson
    I had Shadbolt Cams in Vancouver BC do mine. Reground a 8BA cam and it cost me around $210 CDN.
  13. deucemac
    deucemac
    Schneider Cams (619) 297-0227 . Jerry Cantrell is the man all cams are custom ground for you application, unless you just have to have a catalogue
    6-bangertim likes this.
  14. 64Pony
    64Pony
    Checked and no cores. Placed my order for a new one from reds. Got plenty to keep me occupied in the meantime.
    Thanks for all the replies.
    Ziggster likes this.
  15. Nothing wrong with new,,,,,,Reds has good stuff .
    The pic of your block looks really good .
    Tommy
    5window likes this.
  16. Ziggster
    Ziggster
    Of course after I posted this, today I see an ad for a cam for CAN$20. Lol!
    https://www.kijiji.ca/v-engines-and...ord-flathead-flywheel-and-camshaft/1550311117
    kidcampbell71 and Desoto291Hemi like this.
  17. 64Pony
    64Pony
    Just got my 1007b delivered today. Should have the rest of my parts in by end of week to start the build up. I think I’ll be in the engine around 5k. Things add up fast lol
  18. Ziggster
    Ziggster
    Sounds about right. Machine shop costs for me were CAN$2,4K for a short block and I supplied all the parts. I haven’t checked my parts spreadsheet in a while, but I think parts were about CAN$2.5K for a stk rebuild (no fancy alum heads, intakes, or new carbs - this is where costs skyrocket).
    In case you aren’t aware, I’ll just mention that I went with a regrind of my original cam because I had read several threads/posts about some serious quality issues of the new Isky cams.
    adam401 likes this.
  19. adam401
    adam401
    As someone who's about to put a brand new Isky 400jr to use thats not what I wanted to hear but thanks for the heads up. I guess its better to see trouble coming haha
  20. Ziggster
    Ziggster
    Yeh. Can’t recall the specifics, but I do remember at least for the 1007B there were some issues not sure about yours. I also went with the orig USA made Johnson adjustable lifters vs off shore stuff because of issues guys were having with insufficent hardness and consequently rapid wear/damage.
  21. 64Pony
    64Pony
    I’ll make a prayer to the hot rod gods before install.
  22. Truckedup
    Truckedup
    A few years back Delta cams was having problems. a few of us used Oregon Cam Grinding with execellent results...
