Hot Rods where are you putting gas tank in channeled Tudor
Discussion in 'The Hokey Ass Message Board' started by 29tudorA, Oct 29, 2022.
  1. 29tudorA
    29tudorA
    Like the ***le says .. I’m building a channeled and chopped model a Tudor sedan I’m wondering how some of you did your fuel tanks in your sedan
  2. Cliff Ramsdell
    Cliff Ramsdell
    Mine isn’t channeled but it is chopped 3” and I run the stock fuel tank.
    Cliff Ramsdell
  3. X38
    X38
  4. Kiwi 4d
    Kiwi 4d
    Chopped 3” channeled 1.5” , 28 Tudor. 8” step in the rear frame . Stock gas tank. No practical room in the back for a tank.
  5. Mr48chev
    Plenty of room if you aren't running a stock back seat. Most channeled A sedans are going to have kick in the frame that kills the idea of a back seat anyhow.
    Okie Pete and caprockfabshop like this.
  6. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Even if you channel the body, the floor will still be in the same place atop the frame. If you run a 4 link with coil overs there should be some room between the rear frame rails. May need to raise the floor back there a little higher for a larger tank. If you do it right, the floor could be flat enough to just put a custom seat cushion on top of it.
    Another thought is that many vehicle attach the tank to the inside of the frame rail....like SUVs and Pick up Trucks. Then run the exhausts down the other side and split them back near the rearend. Look under an S-10 and you can see how they did it.
    caprockfabshop likes this.
  7. RICH B
    RICH B
    Behind the back seat, like in an old pick-up.
    Okie Pete, dana barlow and Just Gary like this.
  8. Lloyd's paint & glass
    Are ya ready for this?? BAM! 11 gallon air tank from harbor freight. Slightly modified. I even put a sending unit in it for the gauge. I gave $45 for the tank. Car is gone now but it worked great. 20190325_200116.jpg 20190508_194920.jpg
    Okie Pete and Just Gary like this.
  9. RICH B
    RICH B
    found a picture, Tanks tank set at a slight angle and offset to leave room for the battery next to it.
  10. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I would not build anything that does not have the fuel tank separated from the driving compartment. You can put it where the back seat goes as long as you build a metal enclosure that isolates it from the interior. But then, that ends up being the same thing as just raising the rear floor . Mid fifties pickups had gas tanks behind the seat..............and virtually everyone takes them out of the cab and puts them somewhere else. Its really just common sense .
  11. Okie Pete
    Okie Pete
    Well maybe you should be thinking about building a restoration and not a hot rod .
    Fuel tanks behind the seat in pickups and trucks were industry standard up into the mid 70’s .
    Phil Brown, RICH B and WalkerMD like this.
  12. billfunk29
    billfunk29
    from Minnesota
    Okie Pete likes this.
  13. Mechman_22
    Mechman_22
    from Nc
    Im running the lap bomb and a 10gal in the rear on my 30 tudor. will prob only run one while around town and use both on long trips
  14. shortypu
    shortypu
    My 31 is 5'' stepped in the back but not channeled so i built a frame and sat a mustang 20 gal tank with open bottom with a bulkhead thats sealed.One day it will get padding and upolstry. IMG_3706.JPG IMG_3769.JPG IMG_4182.JPG
    Just Gary, chrisp and Okie Pete like this.
  15. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Amen to that..... The late sixties I was handed a strange Ford truck.
    Directed to an out of state recovery tow I put a couple bucks in it discovering the the fill neck had a prob.
    I asked this girl I had recently met If she would like to go for a ride.
    By the time we made the hookup, I was profusely apologetic.
    Upon return we were both senseless.
    ekimneirbo likes this.
  16. Okie Pete
    Okie Pete
    Sounded like a lack of maintenance issue . Tow truck Tom . I have spent every winter feeding cattle in a 71 F250 . Tank behind the seat . With no issues. Have replaced the hose on the filler neck once . Yes I realize that there may be better locations for a fuel tank but why reinvent the wheel.
    RMR&C and sidevalve8ba like this.
  17. ekimneirbo
    ekimneirbo
    from Brooks Ky
    If you only drive the truck on your ranch/farm there isn't much real danger. If you actually drive it on a highway, the reason is because todays *****ic version of humanity believes that actually driving their vehicle is of secondary importance and a nuisance while texting. Ask yourself why manufacturers no longer put their gas tanks inside vehicles. Should we have stayed with mechanical braking systems as well? :)
  18. Okie Pete
    Okie Pete
    We have different opinions. You do what makes you feel safe . Might as well add air bags to the dash and in the doors that pop open in a crash .The roads I travel with the 71 F 250 are very busy with people in a hurry going hunting or fishing or late for work .
    RMR&C likes this.
  19. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Well did not want the thread high jacked but I guess it is.
    So back to the question
    This is a good solution. It does not encroach on the seating area.
    The usual remedies,,,,
    ( deuce tank or or side rail under splash aprons )
    are not available because of the channeling.
    Likely though, would warrant a fuel pump.
    I bookmarked Cliff's project because it is very well done with good sense techniques.
    Will be using it later.
  20. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Did not mean to hi jack the thread, but simply point out that there is more to consider when relocating a fuel tank than if it will fit somewhere.
  21. lostone
    lostone
    from kansas
    I've been toiling with this problem myself on my 31 tudor.
    3" chop, 3-1/2" channel and I want to keep the back seat. So it leaves me with 2 choices, 1-behind rear seat or 22-32' style gas tank.
    Option 1 is easier as I added 4-1/2" to my frame when I built it from scratch so I didn't have to set back the firewall and loose room inside but I hate the idea of it being in the cabin.
    Option 2 I like from the point of view it's outside the cabin, but, it's easier to damage if rear ended and I really don't want the look.
    So.... I still contemplate......
