Where can I get a steel dist. gear ?
Discussion in 'The Hokey Ass Message Board' started by RDAH, Jan 12, 2012.
  1. RDAH
    RDAH
    from NL, WI
    I want to put a duraspark dist in my 54 Merc with a 91 302 that I also changed over to a carb set up. Of course Ford changed the shaft size on both dist. so I can't take the 91 gear & put it on the 80 shaft. 91 shaft is bigger than the 80.
  2. chaddilac
    chaddilac
    PM GMCBubba....
  3. gallagher
    gallagher
    from califorina
    i bought mine from the ford dealer that carryed ford motorsports parts was like 35 but that was 10 years ago
  4. Summit Racing or perhaps Jeggs is also a good place to look. Try looking in their online catalog or calling the toll free number and asking.
  5. BlueGhost
    BlueGhost
    Ford racing sells them. The other thing to do would be by a duraspark distributor for a 85 carbureted Mustang.
  6. RDAH
    RDAH
    from NL, WI
    Bubba does'nt have one, just has GM gears. The local Ford guy = huh, guess he's not in the know about Ford motorsports. I'll give Summit a call next. Thanks guys for the info
  7. RDAH
    RDAH
    from NL, WI
    Next time I do this dist swap & when it's a little warmer out I'll for sure take your advice BlueGhost & hit the salvage yards.
  8. sunbeam
    sunbeam
    MSD and Mallory sell them mallory is about 1/2 the price of MSD.
  9. hotroddon
    hotroddon
  10. RDAH
    RDAH
    from NL, WI
    Yuuuup Summit has them.
  11. jack orchard
    jack orchard
    what determines the composition of the cam gear? (steel, bronze, etc) thanks, because i don't know...jack
  12. boutlaw
    boutlaw
    Cam manufacturer's recommend using a soft dist gear for roller cams, such as bronze. Flat tappet camshafts can be run with a steel gear. Had to change the distributor gears on MSD distributors for use in roller SBF and BBF roller engines. I've got some SBF & BBF steel gears that were original on the MSD distributors. Doubt if the shaft size is the same as Duraspark.
  13. AnimalAin
    AnimalAin
    Flat tappet cam needs a cast iron gear; the hydraulic roller cams need either a steel gear, bronze, or the composite. Steel is much more durable than the bronze, what I have in my two motors.
