Where can I get cracked Willys block welded in So Cal?
Discussion in 'The Hokey Ass Message Board' started by Weasel, Jul 16, 2012.
  1. Weasel
    Weasel
    As the ***le states, I need to get a cracked block - and head on a Willys 77 engine welded/repaired so it can be used for restoration of this very rare 1933 Willys Roadster? Any help/leads and actual experience would be much appreciated
    Cheers fellas....
  2. try egge machine in santa fe springs, L&R engines in santa fe springs, H&H flatheads,
  3. Weasel
    Weasel
    Thanks - all good suggestions but I was looking for places that do the work in house. I think these guys sub it out. I was also going to call Taylor Engines but I am sure they subcontract that work too.
  4. swissmike
    swissmike
  5. porkshop
    porkshop
    from Clovis Ca
    shedlers here in fresno does it in house. I dont think I spelt that right
  6. Gasser1961
    Gasser1961
    Valley Head Service
    valleyhead.com
    They do everything from race cars to vintage engines.
  7. Weasel
    Weasel
    Thanks guys - keep those suggestions coming....
  8. jazzbum
    jazzbum
    yup. sterling reputation.
  9. ryno
    ryno
    it might help if you had a more pin pointed location?
    if your in the San fernando valley area, you might give jamie a call at fab tec welding in north ridge/canoga area...
  10. jfrolka
    jfrolka
    slim from slims welding in simi valley is the best iron welder in the land.. nobody can wave a stick at him
  11. Weasel
    Weasel
    Engine is in Long Beach....
  12. DualQuad55
    DualQuad55
    from NH
    Cool car, that makes three that I know of here in the states.
  13. Weasel
    Weasel
    There are more than that - there's at least one on the East coast, Pure Choice has one in Havasu, I have two. There's one I sold down the road apiece currently under restoration, Bob Panella may have one, there's one in Indiana - are the ones you know of in addition to this lot I've listed? Original production is listed as 74 units. There are still three I know of in Australia....
  14. bohica2xo
    bohica2xo
    from Las Vegas
    Last time I needed a cast iron engine part welded in So Cal, I had it done at Cyclone Excelsweld out on Arrow Highway in Baldwin Park.
    I don't know if they are still there, that was about 10 years ago. Back then they were the only place to take a cracked Mack diesel cylinder head or block.
    Hope that helps.
    B.
  15. DualQuad55
    DualQuad55
    from NH
    Yours (now two), Bob Panella had one although it may have been a 35-36. I saw it about 22yrs ago.
    and I sold a complete hulk of a shell at GoodGuys Indy about 11yrs ago. It had just the cowl, firewall, dash, windsheild, one door, two rough 1/4 panels and the weld in spare tire panel was there but cut out. It also had with it a bare Chuck Finders rectangular tube frame.
    Trying to remember who bought it. Thinking he was from northern central USA. He dealt with alot of Willys stuff.He had Bought a bunch of 33 stuff from my dad at the same show and previously.
  16. flynstone
    flynstone
    elco welding...................venice
  17. call lloyd's welding in redondo beach. 310) 374-5944
    also... Marsh Weldcraft in Hawthorne (310) 676-2391
  18. Sheep Dip
    Sheep Dip
    from Central Ca
    I'll second this one, I have had them fix some non auto related items that I was convinced was a lost cause and the y turned out really good.
  19. Shaggy
    Shaggy
    from Sultan, WA
    I dont want to sound like an ***, but i cant see it being that hart to find early willys parts since everyone seems to build rods outta them, Somebody on here has to have a decent head. Btw what years/models fit?? i know atleast one local guy that is rodding a willys
  20. Weasel
    Weasel
    The 1928-1939 Willys L134 heads have a different head bolt pattern to the later 61 and then 63hp heads. So the answer is that any kind of original Willys part from 1933-1936 - during the era of the Model 77 is really tough to find. You just never see them and networking with other Willys owners is about the only way to go. I am still looking for an original 1933/34 or possible 1935 frame and an original 1933-36 rear end....
  21. Vimtage Iron
    Vimtage Iron
    If all else fails in SO Cal there is American Cylinder Head in Oakland, they do their work in house, I've had tractor heads repaired there, I don't know how big he can do, the block on that Willys isn't much bigger than some tractor heads.
  22. 39WILLZ
    39WILLZ
    Guido ive got engine,trans rear axle front axle from a 36 and front and rear axles fom a 33 Willys if there any good to ya but there in the UK cheers Wayne
  23. Roger O'Dell
    Roger O'Dell
    Have you thought of stiching. An old way of repairing cracked eng blocks. By drilling and taping.
  24. kays kustom
    kays kustom
    from california
    guido a guy called phil in new york is selling a ch***is rolling with engine i have his number if you want it
    also try jack runner he has lots of 77 stuff i got his number if you need it too
    talk soon
    lee
  25. Taylorengines
    Taylorengines
    from Brea, Ca.
    Claro's Welding.. Call me Monday and I'll give you the number, Also there is a guy in Gardena that is amazing but slow, which there is nothing wrong with for Quality work..
    Chris
  26. Rooster Motors
    Rooster Motors
    from SFV
    I would not recommend Marsh Weldcraft to nobody....I went to Larry from Marsh Weldcraft because I thought that someone in business for 45 years would be a good place to go. WRONG! I gave him 10 aluminum oil tank to weld; When I picked them up I was chocked by the poor quality of the weld. None of the bungs he welded where aligned (I mean beyond bad!), some where burned thru and needed to be re-threaded. Over all he welds were not consistent and look very amateur.....But the worse thing he did was not being careful at handling the tanks, 4 of them had major dents and could not be fixed, 6 of them were deeply gouge and I was able to sand down 4 of them. Conclusion out of 10 tanks he welded I sold 4 at a loss and discarded the rest. Stay away from Marsh Weldcraft if you need professional work.
