where can I get rubber/urethane stock for custom mounts?
Discussion in 'The Hokey Ass Message Board' started by Ohmboy, Mar 17, 2009.
  1. Ohmboy
    Ohmboy
    from Dallas
    I am retro fitting a 700r4 behind my '60 394 olds and am in need of think, strong, rubber or urethane pads for my custom mounts (rectangular). I have some trans mounting pads that are about 1/2 inch thick, but wanted something thicker. Does anyone have a source for this stuff?
  2. Your nearest hockey rink ( can you tell I'm a Canuck?)
  3. SlowandLow63
    SlowandLow63
    from Central NJ
    Eh, good idea. :D (He's refferring to using a hockey puck.)
  4. noisey
    noisey
    from central ok
    Go to the big truck supply house. They have rubber pads for mounting heavy stuff.
    I've been using: Euclid part # E1330 about 5" x5" X1" thick.
    Cut them with a sharp knife, and make you a hole puncher out of a 1/2" pipe nipple.
  5. scottybaccus
    scottybaccus
    Energy suspension has a race duty poly trans mount that is pretty thick and can be spaced down from the tranny. I grabbed one at AutoZone for about $20. Two bolts on the bottom rather than a single, interlocking plates to prevent tear out.
  6. Charlie DeLong
    Charlie DeLong
    McMaster - Carr has a lot of shapes and sizes.
    Charlie
  7. Ohmboy
    Ohmboy
    from Dallas
    Hey Charlie - what/where is MacMaster? I found MacMaster-Carr with a boat load of products - is that is it, what is it listed under?
  8. boldventure
    boldventure
  9. Old Rotor Flap
    Old Rotor Flap
    from Colorado
    MSC which is Manhatten Supply Co also has material shapes/stock. You can also buy casting urethane - Google; Freeman supply, they have a great DVD on working with molds etc.
  10. Ohmboy
    Ohmboy
    from Dallas
    Thanks RotorFlap ;-) I went to MSC and found exactly what I needed. PERFECT!
    Also thanks Noisey, I used your hole punch method last night and it worked like a champ. Took a copper pipe, sharpened the end a bit with a file and punched a perfect hole using a large hammer and block of wood. I found a coil spring spacer that was close to what i was looking for, but was a great tester.
