Where can I tach for a 6 volt positive ground car?
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, Oct 18, 2011.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    I want to put a tach in my '53 Desoto. The car has a 251 l-head six, and is still 6volt positive ground.
    I imagine this could take forever to find one that will work.
  2. pick
    pick
    they're pricey but work great have 1 in my "A" banger. google "Westach"
  3. hillbilly4008
    hillbilly4008
    from Rome NY
    Thanks for that link. I found a couple, the $119 seems to be on par with other tachs I've seen for sale on ebay. This is the first verified 6 volt positive ground tach I've found. I just wish it was a little bigger than 2"
  4. ct1932ford
    ct1932ford
    I checked out Westach as well and only saw 2" tach's. Looking for something more traditional. In a 6 Volt pos. gnd.
  5. jan bogert
    jan bogert
    SNYDER'S ANTIQUE AUTO PARTS $125.00 works great 2 wires one to + of coil one to - of coil
  6. hillbilly4008
    hillbilly4008
    from Rome NY
    More traditional looking, But it's still only 2". I'd pick this one over the Westach though
  7. Vimtage Iron
    Vimtage Iron
    I've run a 6 volt westach and have had problems with it, sent it back they looked it over and still does the same thing, when off it reads 1000 revs, I just let it go.
  8. edweird
    edweird
    my dad bought a new one for his 41 stude and has never used it. the car is getting converted to 12 volts anyway. i can find out what he wants for it if you like.
  9. BigJim394
    BigJim394
    You might be able to run an old Sun "Half Moon" Tach, the type that used a sending unit. The 6 volt sending units usually do no go for that much money. If you dont need a high RPM tach, the ones that go to 4,000 or 5,000 RPM dont bring the premium prices.
  10. hillbilly4008
    hillbilly4008
    from Rome NY
    Yeah, I don't need a high reving tach. 4grand would be plenty, the ol' L-head six doesn't like to spin that fast.
    Edweird, let me know buddy. I'd appreciate it.
  11. MORRISGAUGE
    MORRISGAUGE
    A note on the old Sun sender "buzz" boxes: they need to be completely gone through before installed. The original hard wired batteries need to be replaced and the trigger mechanisms need to be cleaned and adjusted. Calibration also has to be fine tuned and is best performed with the tach. All this adds up to a fair amount of labor, $. There are later "V" type solid state senders that work positive and negative ground, but they are rare. If you can tolerate the Westach unit, they're a good deal. I usually recommend a mechanical tach, they are a simpler design and rarely fail, especially if serviced.
