Technical Where did you mount your horn on your hot rod or custom?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 6, 2021.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Does a Tugboat sound anything like a Foghorn? :D HRP
    WB69 and Stogy like this.
  2. Stogy
    Stogy
    Thanks Rand...Yes there was a Build Thread on the Hotrod and that roof was actually covered in some detail as is the rest...problem is the ravages of redx syndrome have nailed many pics...:oops:
    https://www.jalopyjournal.com/forum...oject-for-the-wife.464364/page-6#post-5768325
    :rolleyes:...BUT...here's a link to the roof fabbing stage...It is Hamber @Koz who fabricates these tops...he worked with Jerry on it and typically they get covered but this one they left bare and I feel it resonates a WW11 aircraft skin ambience...it also uniquely flows much like the Canvas top that graced it as a Sport Coupe...
  3. -Brent-
    -Brent-
    I am going to mount mine (Model A Coupe) on the inside of the p*** side frame rail, like Tom McMullen's roadster.
    Just Gary, Lil32 and Stogy like this.
  4. 5window
    5window
    I'm running an Ahooga horn in my A coupe sitting just outboard of the frame rail near the firewall-Open engine, no hood
  5. Canuck
    Canuck
    P***enger side frame rail just behind front cross member. Horn is a unknown picked up at a swap meet cause it looked neet. Cleaned and re***embled, 6v horn running on 12v, loud and annoying.
    UNCLECHET, -Brent-, bchctybob and 3 others like this.
  6. lostmind
    lostmind
    @Canuck, I have a horn like that in the cl***ified section , Delco Remy shorty.. You described it right, loud and very annoying. I can't find info on it other then someone told me they installed them on boats at his marina.
    Stogy likes this.
  7. Canuck
    Canuck
    Lostmind, I have seen similar ones for boats, but they had shorter trumpets and were pretty and chrome, mounted on the deck or roof. It was a Swap Meet packing up time buy, I think .25 or 50 cents, vendors asking so he wouldn't have to take it home. He didn't know what it was off. What I could find out about mine when re-building, was possibly 1953 Jeep.
    Stogy likes this.
  8. mrspeedyt
    mrspeedyt
    i’ve a italian accessory horn sitting in my garage … two trumpets and the air compressor… maybe i will mount it as a backup horn on my 41 cad…
    Stogy likes this.
  9. blowby
    blowby
    from Nicasio Ca
  10. BJR
    BJR
    On my 49 Buick I run the original 6 volt Horns on 12 volts. Loud as hell.
  11. Ned Ludd
    Ned Ludd
    A lot of my daydreaming around the '31 involves going to town on an engine-driven OBA system, and running as little as possible on electricity. An air horn is an obvious part of that, actuated by a physical air valve and not an electric solenoid valve.
    I've always liked the thing some French cars had in the '50s, two horns with a switch between them, one for ville (soft) and another for campagne (loud). With my perverse propensity for complicating things I've been wondering how to pull that off with air. The loud horn isn't a problem, but you'd be surprised how hard it is to find a soft horn! It's looking like a bicycle squeeze-bulb horn hooked up to air via a regulator, i.l.o. the bulb, might do the trick. I haven't been able to find any dB figures on squeeze-bulb horns, though: the closest are reviews on bicycle sites describing them as "not nearly as loud" as more modern options.
    I'd expect that all of this would occupy the real estate between the bottoms of the headlights and the tops of the frame rails.
    Stogy likes this.
  12. Behind the front bumper.
    Stogy and Just Gary like this.
  13. Jacksmith
    Jacksmith
    from Aridzona
    The Stude has a Musket Horn from HornBlasters mounted on the inner fender-well. Sounds like an ol' school Semi.
    Stogy likes this.
  14. GordonC
    GordonC
    I have a pair of horns mounted down low behind the front crossmember. I think they were out of a BMW? Small and loud and can't be seen unless your really looking for them. Appropriate thread HRP. I just installed a new steering column and was chasing horn wires yesterday! Plus my buddy just bought an off topic fibergl*** car that the horn isn't working on and I am helping him diagnose that!
    Stogy likes this.
  15. seabeecmc
    seabeecmc
  16. jnaki
    jnaki
    Hello,
    A horn was something we all had to have. The CHP patrol car check points were set up all over our So Cal cruising grounds and most everyone had to stop. If it was a cool looking car with teenagers inside, more than likely, it was designated to pull over for a full inspection. Sometimes it was set up far enough ahead that one could see the stoppage and turn around, if something in the hot rod or cruiser was not "...According to Boyle."
    When we were messing around with horns on our 1957-58 Chevy sedans, we wanted something different. So, we tried to modify the sound coming out of the horns. The best sound was putting tape over one of the horns for a different sound. It still pointed out to the front and from a few car lengths away, could still be heard with the single horn sound.
    We tried all sorts of different connections, disconnecting one and capping both with an old t shirt, to using steel wool stuffed into one horn. Each had a distinct sound.
    Jnaki
    What was the one used on the 57 Chevy Bel Air and the 58 Impala? One horn fully functional with an old t-shirt stuffed inside as deep as it would go, inward. The distinct sound immediately told everyone it was “us.” It also made other cars whip around at the unique sound coming from our Chevy sedans when it was necessary to beep the horn as a warning.
    We were early sound editing professionals… Ha! As we cut the old T-Shirt strips and stuffed then inward to varying depths, the sound changed. The best sound was a single horn with a T-Shirt stuffed all the way to the back surface.
    The 327 powered 1940 Ford Sedan Delivery
    So, I had an old Chevy horn sitting in a box during our 1940 Ford Sedan Delivery days. I took out the stock horn and replaced it with the Chevy curved horn and immediately stuffed in a torn T-Shirt for the unique sound. It always reminded me of our teenage high school days and the one-of-a-kind horn sound.
    But, the odd looks from other drivers was the key to chuckles and being noticed when it was close to an emergency. Was it legal? Once was enough, as we never got stopped for a vehicle check or non-moving violation during the rest of the time we owned and drove the sedan delivery all over So Cal. Because a horn was mounted behind the grille, it made a cool noise. The CHP check point officers smiled and the inspection continued for the rest of the street legal hot rod sedan delivery. YRMV
    mitch 36 and Stogy like this.
  17. Blake 27
    Blake 27
  18. Deuce Daddy Don
    Deuce Daddy Don
    Under drivers side floor---Where the OOGAA sound reflects off the pavement just fine.
    On a funnier note-----There is one mfg. on UTUBE that makes a loud AK47 noise that sounds real!---A slow moving dude just shucking along----When you hit the ****on & gunfire noise erupts----WOW! you should see him haul ***!!!!!!!!!
    Stogy, Lil32, bchctybob and 1 other person like this.
  19. chevy57dude
    chevy57dude
    In Baltimore the sound may cause an entire city block to start shooting back..
    Just Gary, Stogy and bchctybob like this.
  20. Deuce Daddy Don
    Deuce Daddy Don
    Nation wide had better get used to it!
    Stogy and chevy57dude like this.
  21. bchctybob
    bchctybob
    What’s wrong with me? None of my hot rods have a horn mounted anywhere and I can’t remember the last time I honked the horn on the family truckster. The loosely dangling Ahoogah horn was the first thing to go on my Model A coupe. (Wasn’t working anyway). I do have a box up in the loft full of a variety of horns but none have ever found their way downstairs and onto my cars. Maybe I need to start taking Enzyte….. I guess I’m just a hornless lawbreaker. Smilin’ Bob
    P.S. I have always wanted one of those Bermuda Bells that they used to advertise in the Almquist ads.
    Stogy likes this.
  22. Paulz
    Paulz
    The "beep beep, hi how are ya?" horn is behind the grill in front of the radiator.
    The "RESPECT MAH AUTHORITAY!!!!" air horn from a Volvo semi tractor is under the floor next to the transmission.
    Ned Ludd likes this.
  23. Dreddybear
    Dreddybear
    I don't have one and I have not thought about putting one. As such if I do need to "remind" someone I'm there I just give a quick blip of the throttle and they know...
    bchctybob likes this.
  24. Smoothur
    Smoothur
    I went for an aftermarket Harley Davidson horn, you know, the kind that's got that cl***ic vibe. But here's the kicker: I wasn't digging the chrome look, so I busted out the sandblaster and gave the cover a sleek black paint job.
    Now, when it came to mounting, I decided to go for the firewall. It just felt like the right spot—easy to reach when I needed it but tucked away enough to keep the front end clean.
    But hey, if you're still on the hunt for horn options or just wanna see what else is out there, check out https://bosshorn.com. They've got some pretty cool horn solutions that might just take your ride to the next level.
  25. Rickybop
    Rickybop
    My head out the window..
    LOOK OUT!!! :eek:
    :D
  26. -Brent-
    -Brent-
  27. Rickybop
    Rickybop
    I'm thinking about making mine pretty and mounting them right up front between the fog lamps.
  28. flynbrian48
    flynbrian48
    Under the trunk floor, behind the rear axle, ahead of the rolled pan. 6V trumpets on 12V, 2' long, they're LOUD!
  29. 26 T Ford RPU
    26 T Ford RPU
    My Clear Hooters horn on frame rail. JW
  30. A 2 B
    A 2 B
    from SW Ontario
    Train horn mounted in between the brake master cylinder and a '50s police siren under the floor access door. Not sure about legality but they sure are loud.
